No more GM Synchromesh Friction Modified!
Old Dec 27, 2007 | 10:47 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default No more GM Synchromesh Friction Modified!
*edit* This post is about the <u>Friction Modified</u> version of GM's Synchromesh. It is NOT about the regular Synchromesh fluid, either from GM or from Pennzoil
Yup. Called up my buddy yesterday at the big local Chevy dealer, looking for some Friction Modified Synchromesh before I pull my engine out. He brought out 3 quarts of the regular Synchromesh, and told me that the Friction Modified version is being phased out.
So I took the regular stuff, and then just as I got down the street aways he called me back and said he found some Friction Modified fluid.
So I went back and decided to buy all 6 quarts they had left, for the most excellent price of $51
So I guess if you use it and want to keep using it, or if you've been wanting to try it, you better call around to your local GM dealers and try to stock up now before they get rid of it.
A little history: I've been using GM Synchromesh Friction Modified fluid in my GS-R transmission for about 100,000 miles now, changing it about every 25K miles or so. My transmission has 260K+ total miles on it, still with all original internals, and it still shifts flawlessly, even with my short shifter, even in single-digit temperatures on cold mornings. It is by far the best fluid I've ever used.
Mods I'm cross-posting this in several forums so that everyone will see it.
Modified by PatrickGSR94 at 7:58 AM 12/28/2007
Old Dec 27, 2007 | 10:56 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: No more GM Synchromesh Friction Modified! (PatrickGSR94)
Dang. People will actually have to fix their transmission now. What are the other fluids available?
&lt;-- Always used Honda MTF with no problems. But my '97 GSR only has 72000 miles.
Old Dec 27, 2007 | 11:04 AM
Community Builder
yep, the Friction modified stuff isn't even listed in their system anymore.
It's hard for me to say if SM FM is better or the same or not as good as Honda MTF. I bought my car with 90K on it and used Honda MTF for about 70K miles. Then I switched to GM SM FM and have been using that for 100K miles.
It felt to me like shifting was a touch easier when I first made the switch, and the fact that I still have flawless shifts with 260K on the tranny would lead me to believe that GM FM SM is at least as good, if not better, than Honda MTF. But I have no proof of that.
Old Dec 27, 2007 | 11:07 AM
Fern413's Avatar
Default Re: (PatrickGSR94)
Damn this sukks....
Old Dec 27, 2007 | 03:28 PM
Mr. DB2's Avatar
I was allways curious about it,but I've allways used Honda MTF in my GS-R and with 270k miles it still shifts with no problems.I didn't want to change and have something go wrong.
Old Dec 27, 2007 | 03:55 PM
1200 Hobos's Avatar
Default Re: (Mr. DB2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fern413 &raquo;</TD></TR><TR><TD CLASS="quote">Damn this sukks.... </TD></TR></TABLE>
X2, time to stock up.
Old Dec 27, 2007 | 05:04 PM
tasco's Avatar
And I heard that honda changed their mtf to a different formula that is thin like water.
Old Dec 27, 2007 | 05:09 PM
Community Builder
Default Re: (tasco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tasco &raquo;</TD></TR><TR><TD CLASS="quote">And I heard that honda changed their mtf to a different formula that is thin like water. </TD></TR></TABLE>
doubtful... Honda transmissions require a 5w30 viscosity fluid, which is what Honda MTF is. If they made it thinner it wouldn't be 5w30 anymore.
Old Dec 28, 2007 | 05:18 AM
b18LS's Avatar
If the friction modified isnt available, go with amzoil synchromesh. Its the only other stuff id use besides MTF.
Old Dec 28, 2007 | 05:24 AM
WinningNinja's Avatar
Default Re: (b18LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18LS &raquo;</TD></TR><TR><TD CLASS="quote">If the friction modified isnt available, go with amzoil synchromesh. Its the only other stuff id use besides MTF.</TD></TR></TABLE>
+1 for Amsoil.
Old Dec 28, 2007 | 08:04 AM
team714's Avatar
i use royal purple synchromax
Old Dec 28, 2007 | 10:16 AM
ooopseyesharted's Avatar
Default Re: No more GM Synchromesh Friction Modified! (team714)
Since I am lame and have an auto tranny. Could someone tell me what fluid to use in my tranny?
Thanks
Sorry about the thread hijacking
Old Dec 28, 2007 | 10:23 AM
Default Re: No more GM Synchromesh Friction Modified! (ooopseyesharted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ooopseyesharted &raquo;</TD></TR><TR><TD CLASS="quote">Since I am lame and have an auto tranny. Could someone tell me what fluid to use in my tranny?
Thanks
Sorry about the thread hijacking </TD></TR></TABLE>
ATF
Edit:
https://honda-tech.com/zerothread?id=48916
Old Dec 28, 2007 | 12:25 PM
TomsDC's Avatar
so what is the diff between HMTF and regular 5w30 or 10w30? a few of my friends use syntec 10w30 and some lucas oil stabilizer and they have been runnin that for a long time on high HP cars and stock trannies. im a noob so forgive me and dont hurt me too bad please.
Old Dec 28, 2007 | 12:33 PM
Community Builder
Default Re: No more GM Synchromesh Friction Modified! (TomsDC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TomsDC &raquo;</TD></TR><TR><TD CLASS="quote">so what is the diff between HMTF and regular 5w30 or 10w30? a few of my friends use syntec 10w30 and some lucas oil stabilizer and they have been runnin that for a long time on high HP cars and stock trannies. im a noob so forgive me and dont hurt me too bad please.</TD></TR></TABLE>
Honda MTF is a 5w30 fluid, but with friction additives to aid in synchronizer operation (which rely on friction to function properly).
I don't know why in the hell you would want to put oil stabilizer in your transmission, but synthetic motor oil is BAD for a transmission, even worse than conventional motor oil, as synthetic is much too slippery for proper synchronizer operation.
Old Dec 28, 2007 | 05:11 PM
SlammedDC2's Avatar
Semper Fidelis
Looks like I'm calling Chevy and GM tomorrow to buy what they have left. Thanks Patrick
PatrickGSR94
Mar 8, 2013 09:18 AM
Ladolcettad
Transmission & Drivetrain
12
Jan 12, 2012 07:18 AM
PatrickGSR94
31
Jan 5, 2008 07:50 AM
NorthernXposure
Apr 23, 2007 11:48 AM
B2FiNiTY
Oct 27, 2003 03:27 PM
