dead spot???
after driving my car for about 10 or 15 min, it has a dead spot around 2k rpms. i did a small tune job - plugs, wires, cap and rotor button but the problem is still there. i have a 93 eg hatch with the d15b7 in it. any ideas??? is it maybe the coil? also, when this problem begain my gas milage really bit the dust. plus no power. if i could just get some ideas of where to start next that would be great. thanks for the help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi »</TD></TR><TR><TD CLASS="quote">What the hell is a "dead spot"?
it bogs down real bad at 2k rpms after that its normal again. sorry i didnt explain that very well. its just sluggish down low and never was before.
</TD></TR></TABLE>it bogs down real bad at 2k rpms after that its normal again. sorry i didnt explain that very well. its just sluggish down low and never was before.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phyzJunkieCivic »</TD></TR><TR><TD CLASS="quote">What is a dead spot?
You mean like the cars rpms stuck at 2k and can not pass it? How does it sound? Does it bog, sputters, lack of power?</TD></TR></TABLE>
sounds normal, bogs bad, lack of power is just on bottom end of gear. sputters somewhat. hard to explain. lol. what would you say it is?
From: Dont You Just Love Lynn Cops, Boston MA, USMA
Umm its been a few years back when i had that problem
First thing i would do is check the dizzy, it might be the coil also.
Check the o2 sensor it might be bad, since o2 tells the ecu how much fuel to feed.
Also check the map sensor or tps.
I dont know if these things i mention might help or not. Some one here should know the problem.
Because i had another problem, the rpm was cutting out at 7,000. Couldnt find the problem until i sold the motor. New motor when back in an had the same problem. Stupid me forgot to put a crush washer on the bango on the AEM fuel rail.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phyzJunkieCivic »</TD></TR><TR><TD CLASS="quote">Good to hear you fix the problem. I think the fuel filter probley clogged up or something.
How many miles was on it?
its right at 120k miles. fuel gauge doesnt work so ive been running it out of gas alot. i probly picked up lots of crap out of the tank and got it stuck in the fuel filter. its just weird that it would only do it at low rpms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phyzJunkieCivic »</TD></TR><TR><TD CLASS="quote">Umm its been a few years back when i had that problem
I dont know if these things i mention might help or not. Some one here should know the problem.</TD></TR></TABLE>
by the way thanks for the help man. i did check all that but i had to do the other stuff anyway. im just glad it solved the problem.
midorihatchkid
Jun 3, 2009 03:25 PM
...:::MaRk:::...
13
Jul 23, 2007 08:40 PM
EJ8VTEC
10
Jun 13, 2006 10:32 AM
