Size of K24 engine/tranny
I need the approximate size of the K24 engine and transmission. To keep things simple, it can be treated as a box, H x W x D, and same for the transmission. The other important numbers I need are where the axles exit, relative to the side and bottom of the drivetrain.
I know this is a lot to ask, but I'm hoping that someone has a drivetrain out of their car so it would be easier to measure.
Oh and while I'm asking, I may as well ask for weight too, though I assume it's about 450lbs complete.
Thanks!
Modified by kb58 at 12:26 PM 12/27/2007
Thanks!
try asking a company that sells motor swaps to help you out. Just act like you are real serious in buying and maybe they'll jump through a hoop for you.
On K20a.org, try asking user NIKOS, he might be able to help you out.. .
I think the K24/K20 motors are actually a little heavier than the B18. Around 35-40lbs I think. [6spd, taller deck/head height (2" or so)]
