won't EF'ing start!
I just bought my EF back from this dumba$$ the otherday. It wasn't running when I got it back. He burnt the wire from the hood fuse box to the main relay. I fixed that but it won't start. My injectors are not opening. So no fuel to engine. (The EF has a D15B2 w/ MPFI swap)
The main relay is good, checked that.
Fuel pump works, good pressure (36 psi).
Tryed my brother-in-law's injectors (which are good), still nada.
Used my DVOM and got battery voltage at injectors and yellow wire at resistor box, and got good grounds at both.
Tryed my brother-in-law's resistor box, once again nada.
All the wiring seems good, I even put my ECU in my homeboys car and the ECU is good.
I really have no other ideas, please help! This is the first time I've ever needed help with an EF. Thanx
Well, I just got the beast running. It turns out that both sets of injectors were bad. When I did a resistance test, they were too high (11 ohms). So being the Honda nut I am, I went to my toolbox and found a good set of injectors with good resistance (2 ohms). Put them in and voila, she starts and runs. Thanx for ya'lls help anyways.
Fototek7
Jul 27, 2002 01:59 PM
