OBD1 injector identify?
Can someone please identify this injector? Closest to bottom in pic.
The injector on top is a Z6 injector, the injector on bottom is the one in question.
I was told the one on the bottom (from the seller) is OBD1 240cc. It has a black top (the top most piece which goes into the fual rail), a wavy washer underneath the black top versus flat washer on the Z6 injector, and a black round o-ring versus a green flat o-ring on the Z6 injector.
Thanks in advance.
Thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">if the obd1 clips fits then its obd1. The obd2 clip is rounded, OBD1 is squared.</TD></TR></TABLE> Could be peak and hold obd1, thats why the ohms test.
I got 11.8 ohms terminal to terminal. This is also what I got on the 3 Z6 injectors. Did my 96 Y7 injectors and they are also 11.8.
alot of the injectors are the same. You would be surprised. I have tried to look for identifying marks on injectors before, and they all look the same to me. Obd1 and OBD2 are different. Most stock injectors I believe are saturated injectors and some are peak and hold, like a prelude and a 91 Civic Si. I could be wrong...im not an expert,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">was under the impression that OBDI injectors were all peak and hold. Thats the way it is for H22 atleast.
</TD></TR></TABLE> When the Bseries switched to OBD1, 93 or 94 they went to saturated injectors. The H series stayed with peak and hold, the only way to tell is the resistance. Mitsu and Mazda stayed peak and hold for quite awhile also.
BoRiCuA
Jul 6, 2013 08:57 AM
EKB18BPR3
May 6, 2005 08:07 AM
