Idle issue
Old Dec 26, 2007 | 05:57 PM
eric123's Avatar
Default Idle issue
I have a 1991 Honda Accord EX 5 speed, 400,000 km.My problem is it idles at 1600 rather then the normal. I;m not sure how to fix this does anyone have any idea? I appreciate your help
Old Dec 26, 2007 | 06:21 PM
BlUAc's Avatar
Default Re: Idle issue (eric123)
listen to the motor in idle for any vacume hose leaks, try spraying some brake cleaner around some vac hoses to hear any idle changes
Old Dec 27, 2007 | 04:40 PM
hondadude's Avatar
check to see if some mental midget tightened up the throttle cable to jack up the idle, there should be a little slack in the cable.
Old Dec 29, 2007 | 03:43 PM
eric123's Avatar
Ok well i tried cleaning the IACV and now it idles at 600 but stalls as son as i put another load on the engine such as moving the steering wheel, ac, etc. If i rev it, once i let off the gas it almost stalls, drops below 500 rpm's
George2012
Classic Hondas
Jul 12, 2012 02:29 PM
Car Tweaker
Sep 13, 2009 08:28 PM
DAJay93
Nov 30, 2007 11:40 PM
headhunter
Aug 18, 2003 08:14 PM
chirp2hrd
Oct 13, 2002 01:36 AM
