which clutch
Old Dec 26, 2007 | 05:33 PM
Chris Crane's Avatar
Default which clutch
i have a first gen b16a with cable transmisson in my crx and im getting a 2nd gen 92-95 complete change over that im stealing the motor from to run in there, my clutch and flywheel will still work as long as i use the cable not hydro tranny correct??
Old Dec 26, 2007 | 08:13 PM
mellowbeam's Avatar
Default Re: which clutch (Chris Crane)
your not literally stealing it are you...i think we should clarify that before continuing? Anyways....this is something you can research. CLICK the red search tab up there to your upper right. You'll find that its the best invention the world wide web has to offer. Its the main reason this site succeeds IMO.
Old Dec 27, 2007 | 04:51 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Way to tell him to search, yet in no way answer his question. The hydro flywheel will work with the cable clutch, just make sure you buy the one that matches your trans, ys1's have different input spline counts.
Old Dec 27, 2007 | 04:52 AM
Default Re: which clutch (mellowbeam)
i did search and i couldnt get a 100% for sure answer so thats why i asked my question but i guess this is why alot of people dont care for honda-tech cause dick heads would rather type a paragraph about using the search and useless **** then a simple yes or no
Old Dec 27, 2007 | 04:57 AM
Default Re: (ComeOnKip)
but will the 1st gen flywheel work on the 2nd gen motor?
Old Dec 27, 2007 | 05:18 AM
CRX Toad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Crane &raquo;</TD></TR><TR><TD CLASS="quote">i guess this is why alot of people dont care for honda-tech cause dick heads would rather type a paragraph about using the search and useless **** then a simple yes or no</TD></TR></TABLE>
This right here will get you kicked off the board so get rid of the attitude.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Crane &raquo;</TD></TR><TR><TD CLASS="quote">but will the 1st gen flywheel work on the 2nd gen motor?</TD></TR></TABLE>
Yes it will work
3rdtimecharmer
Nov 27, 2012 09:59 AM
JDM-tramp
Jul 6, 2006 03:48 PM
blk007
Jul 13, 2005 04:21 AM
RHDwhor3
Jul 5, 2005 08:42 AM
SiBuddy00
Jun 21, 2005 07:57 PM
