fuel rail question
Old Dec 26, 2007 | 05:06 PM
wicked_b16eg's Avatar
Default fuel rail question
What is that little globe thing at the end of the fuel rail and what is it for.
I have my on therory on what it does, just want to know for sure.
Old Dec 26, 2007 | 05:16 PM
DonF's Avatar
Default Re: fuel rail question (wicked_b16eg)
It is to lessen fuel pulses.
Old Dec 26, 2007 | 05:21 PM
Default Re: fuel rail question (DonF)
What happens when you don't have it.
Old Jan 15, 2008 | 10:48 PM
kasimmmmm's Avatar
anyone?
Old Jan 29, 2008 | 07:17 AM
brightside's Avatar
Default Re: (kasimmmmm)
I would imagine the fuel pressure would pulse a bit with the injectors opening and closing, but you probably wouldn't be able to notice a difference.
Old Jan 29, 2008 | 08:47 AM
Old Renegade's Avatar
Its called a pulsation dampener. self explanitory i guess. you can get a steel braided line made with an fittings "-6". people do this cause in older cars if they go bad they can cause the car to go lean under heavy load. from what i have heard.
Old Jan 29, 2008 | 08:55 AM
Boots's Avatar
Default Re: (Old Renegade)
i took mine off...i have a modified fuel rail with a line that goes straight from the fuel filter to the rail...if you have a basically stock car you're probably not going to benefit from taking it off, but it's not going to hurt anything either
Old Jan 29, 2008 | 11:17 AM
99hondacura's Avatar
From: down the street,bythe river in the van, co, united states
how do you take it off??
Old Jan 29, 2008 | 05:26 PM
brightside's Avatar
Default Re: (99hondacura)
he has a modified fuel rail. changed the banjo setup to either a barbed line or an -AN adapter
Old Jan 29, 2008 | 06:19 PM
Boots's Avatar
Default Re: (brightside)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brightside &raquo;</TD></TR><TR><TD CLASS="quote">he has a modified fuel rail. changed the banjo setup to either a barbed line or an -AN adapter</TD></TR></TABLE>
AN fitting on the end of the rail...take a 17mm wrench and take the dampner off, take off the threaded peice and attach a AN fitting(it's tampered so no need to worry about leaks, but double check anyways) cut off the crimped peiced to the line that goes to the fuel filter, attach hose clamps to both ends of the line and there ya go
Old Feb 1, 2008 | 02:36 PM
manoy's Avatar
Default Re: (boots)
BC_Garage
Aug 25, 2012 01:17 PM
xXSilentScreamXx
18
Aug 14, 2007 04:49 PM
EK FLY
Jan 6, 2006 05:04 PM
t3to4e
Mar 4, 2004 06:58 AM
