wat do u guys think of this motor swap
Old Dec 26, 2007 | 04:05 PM
jdmvtec@413's Avatar
Default wat do u guys think of this motor swap
im thinkin of dropin a b20 block and a b16 head wat u guys think sweet r not
Old Dec 26, 2007 | 04:14 PM
watsvtecEK's Avatar
Default Re: wat do u guys think of this motor swap (jdmvtec@413)
Good setup if you do it right. You have a lot more potential with a 2.0L.
Old Dec 26, 2007 | 04:18 PM
Cln94EG1's Avatar
B20+B16=B20Vtec A strong motor just get it tuned right and u should see 190+ I have one in my Del Sol And just made 204Hp its a powerful setup
Old Dec 26, 2007 | 04:29 PM
Agent_EM1's Avatar
sweet if you do it right.
Old Dec 26, 2007 | 04:49 PM
Default Re: wat do u guys think of this motor swap (Agent_EM1)
so wats the best way 2 do it right besides tuning cuz dats da first thing im doin n wat good pistons should i use
Old Jan 2, 2008 | 03:42 PM
wat can also b the best tranying
Old Jan 2, 2008 | 04:36 PM
pdotjones's Avatar
<A HREF="https://honda-tech.com/zerothread?id=1676914
" TARGET="_blank">https://honda-tech.com/zerothread?id=1676914
</A>
Old Jan 2, 2008 | 04:51 PM
93egSLEEPER's Avatar
Default Re: wat do u guys think of this motor swap (pdotjones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cln92eg &raquo;</TD></TR><TR><TD CLASS="quote">B20+B16=B20Vtec A strong motor just get it tuned right and u should see 190+ I have one in my Del Sol And just made 204Hp its a powerful setup </TD></TR></TABLE>
sick numbers bro for all motor.
b16 tranny will have the shortest and quickest gears besides ITR tranny... i personally like my b16 tranny. if you ever boost make sure to sleeve the block or you will blow it.
Old Jan 2, 2008 | 05:00 PM
Cln94EG1's Avatar
Default Re: wat do u guys think of this motor swap (93egSLEEPER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egSLEEPER &raquo;</TD></TR><TR><TD CLASS="quote">
b16 tranny will have the shortest and quickest gears besides ITR tranny... i personally like my b16 tranny. if you ever boost make sure to sleeve the block or you will blow it.</TD></TR></TABLE>
Hell ya that **** blew my mind I was like over 200 dam
Old Jan 2, 2008 | 05:48 PM
Flint707's Avatar
GSR head flows better on a B20 but if I were you, I'd go B18B bottom end w/ a B16 head, you can rev higher with a 1.8
Old Jan 2, 2008 | 05:53 PM
Cln94EG1's Avatar
Default Re: wat do u guys think of this motor swap (Flint707)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flint707 &raquo;</TD></TR><TR><TD CLASS="quote">GSR head flows better on a B20 but if I were you, I'd go B18B bottom end w/ a B16 head, you can rev higher with a 1.8</TD></TR></TABLE>
That is true but why not just make that power lower in the Rpms lol plus I rev mine to 8k and have the Rev Limiter set at 82k so I think a B20 Vtec is sweet plus girls like it bigger lol
Old Jan 2, 2008 | 06:11 PM
Flint707's Avatar
Default Re: wat do u guys think of this motor swap (cln92eg)
That is true but why not just make that power lower in the Rpms lol plus I rev mine to 8k and have the Rev Limiter set at 82k so I think a B20 Vtec is sweet plus girls like it bigger lol </TD></TR></TABLE>
I think a woman would sacrifice a tiny bit in size for a longer, better ride.
Old Jan 2, 2008 | 06:48 PM
crx_253's Avatar
b20 vtec is a nice set up
Old Jan 4, 2008 | 05:10 PM
Default Re: wat do u guys think of this motor swap (crx_253)
so wat would b best b16 head or b18 or gsr
Old Jan 4, 2008 | 05:22 PM
OMGWTFBBQ!'s Avatar
CRVtec FTW, do eeeeeeeet
Old Jan 4, 2008 | 05:42 PM
iarericky's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmvtec@413 &raquo;</TD></TR><TR><TD CLASS="quote">so wat would b best b16 head or b18 or gsr</TD></TR></TABLE>
a gsr head will flow better
Old Jan 4, 2008 | 07:55 PM
B20VECT2NER's Avatar
Default Re: wat do u guys think of this motor swap (iarericky)
Im more on ls vtec, but like a B20 vtec if its not done right, its not reliable.
Old Jan 4, 2008 | 09:34 PM
hidiouskinky's Avatar
Default Re: wat do u guys think of this motor swap (B20VECT2NER)
i have a GSR motor and i spun a bearing.....i am wondering how easy it is to get a b20 block
right now im rebuilding the bottom end with weisco pistons, eagle rods and ACL bearings....im just curious about the b20 for future reference
Old Jan 4, 2008 | 10:23 PM
ukdmegg5's Avatar
Default Re: wat do u guys think of this motor swap (hidiouskinky)
Id stick with your origional post theres very little difference between a b16a head and a itr
Old Jan 4, 2008 | 11:45 PM
ifIexplode's Avatar
Default Re: wat do u guys think of this motor swap (ukdmegg5)
what if you put a b16 head thatsin an crv already can you hit vtec in a suv. ima lil drunk. be round tomorow
Old Jan 5, 2008 | 03:46 AM
Default Re: wat do u guys think of this motor swap (ifIexplode)
now to do it the right way how should i do it
Old Jan 5, 2008 | 05:06 AM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iarericky &raquo;</TD></TR><TR><TD CLASS="quote">
a gsr head will flow better</TD></TR></TABLE>
lolz at n00bs.
The flow difference between these heads is negligible, stock for stock, neither flows significantly better than the other.
Old Jan 5, 2008 | 05:53 AM
gibsanez's Avatar
Default Re: (Grendel2008)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grendel2008 &raquo;</TD></TR><TR><TD CLASS="quote">I guess I'm the only one that does not like the LS/Vtec or B20 Vtec setup... Hmmm</TD></TR></TABLE>
Based on?
Old Jan 5, 2008 | 06:10 AM
gibsanez's Avatar
I'm not too sure what you mean about "ghetto fab" to get it to work, golden eagle makes a very nice VTEC conversion kit, and other then that it's all OEM parts.
The rod bolts are one of the "weak" spots in the B18A/B bottom ends, shot-peen the rods, get some ARP rod bolts, and as long as the bottom end is put together correctly it'll spin to 8k just as safe as a VTEC block.
Vbiasiny
48
Apr 14, 2006 08:48 PM
HipHapa-Eg
47
Sep 24, 2004 06:15 PM
b16delsol
Jan 26, 2004 11:41 AM
kHoA DoGG
Apr 30, 2002 03:41 PM
