wat do u guys think of this motor swap
Re: wat do u guys think of this motor swap (jdmvtec@413)
B20+B16=B20Vtec A strong motor just get it tuned right and u should see 190+ I have one in my Del Sol And just made 204Hp its a powerful setup
Re: wat do u guys think of this motor swap (Agent_EM1)
so wats the best way 2 do it right besides tuning cuz dats da first thing im doin n wat good pistons should i use
<A HREF="https://honda-tech.com/zerothread?id=1676914
" TARGET="_blank">https://honda-tech.com/zerothread?id=1676914
</A>
</A>
Re: wat do u guys think of this motor swap (pdotjones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cln92eg »</TD></TR><TR><TD CLASS="quote">B20+B16=B20Vtec A strong motor just get it tuned right and u should see 190+ I have one in my Del Sol And just made 204Hp its a powerful setup </TD></TR></TABLE>
sick numbers bro for all motor.
b16 tranny will have the shortest and quickest gears besides ITR tranny... i personally like my b16 tranny. if you ever boost make sure to sleeve the block or you will blow it.
Re: wat do u guys think of this motor swap (93egSLEEPER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egSLEEPER »</TD></TR><TR><TD CLASS="quote">
b16 tranny will have the shortest and quickest gears besides ITR tranny... i personally like my b16 tranny. if you ever boost make sure to sleeve the block or you will blow it.</TD></TR></TABLE>
Hell ya that **** blew my mind I was like over 200 dam
GSR head flows better on a B20 but if I were you, I'd go B18B bottom end w/ a B16 head, you can rev higher with a 1.8
Re: wat do u guys think of this motor swap (Flint707)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flint707 »</TD></TR><TR><TD CLASS="quote">GSR head flows better on a B20 but if I were you, I'd go B18B bottom end w/ a B16 head, you can rev higher with a 1.8</TD></TR></TABLE>
That is true but why not just make that power lower in the Rpms lol plus I rev mine to 8k and have the Rev Limiter set at 82k so I think a B20 Vtec is sweet plus girls like it bigger lol
Re: wat do u guys think of this motor swap (cln92eg)
That is true but why not just make that power lower in the Rpms lol plus I rev mine to 8k and have the Rev Limiter set at 82k so I think a B20 Vtec is sweet plus girls like it bigger lol </TD></TR></TABLE>
I think a woman would sacrifice a tiny bit in size for a longer, better ride.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmvtec@413 »</TD></TR><TR><TD CLASS="quote">so wat would b best b16 head or b18 or gsr</TD></TR></TABLE>
a gsr head will flow better
Re: wat do u guys think of this motor swap (B20VECT2NER)
i have a GSR motor and i spun a bearing.....i am wondering how easy it is to get a b20 block
right now im rebuilding the bottom end with weisco pistons, eagle rods and ACL bearings....im just curious about the b20 for future reference
Re: wat do u guys think of this motor swap (hidiouskinky)
Id stick with your origional post theres very little difference between a b16a head and a itr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iarericky »</TD></TR><TR><TD CLASS="quote">
a gsr head will flow better</TD></TR></TABLE>
lolz at n00bs.
The flow difference between these heads is negligible, stock for stock, neither flows significantly better than the other.
lolz at n00bs.
Re: (Grendel2008)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grendel2008 »</TD></TR><TR><TD CLASS="quote">I guess I'm the only one that does not like the LS/Vtec or B20 Vtec setup... Hmmm</TD></TR></TABLE>
Based on?
Based on?
Re: (Grendel2008)
I'm not too sure what you mean about "ghetto fab" to get it to work, golden eagle makes a very nice VTEC conversion kit, and other then that it's all OEM parts.
The rod bolts are one of the "weak" spots in the B18A/B bottom ends, shot-peen the rods, get some ARP rod bolts, and as long as the bottom end is put together correctly it'll spin to 8k just as safe as a VTEC block.
