Where to buy Adjustable Ends for Strut Bar??
I am not sure what to even call them. Many ebay bars have this fitting they use on both ends to adjust the length of the strut bar. Where can I find those adjustable links??
Here is a picture of what I am talking about.
I need the assembly that threads into the strut bar itself to adjust the length.
you can get them tons of places, teflon lined ones are preferred/better but for a strut bar the quality doesn't matter too much. I get mine from http://www.swracecars.com/
only because they are fairly local and good people jegs etc sells them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisbmx68 »</TD></TR><TR><TD CLASS="quote">you can get them tons of places, teflon lined ones are preferred/better but for a strut bar the quality doesn't matter too much. I get mine from http://www.swracecars.com/
only because they are fairly local and good people jegs etc sells them</TD></TR></TABLE>
I know what a heim joint is, but this is not a heim joint. The heim joint I am typically use to seeing has a rotating assembly in the center.
All this is, is a open hole and then you have the bolt that runs through the mount and into the hole of the fitting itself then back out the other side of the mount.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BodyKits NW »</TD></TR><TR><TD CLASS="quote">I know what a heim joint is, but this is not a heim joint. The heim joint I am typically use to seeing has a rotating assembly in the center.
All this is, is a open hole and then you have the bolt that runs through the mount and into the hole of the fitting itself then back out the other side of the mount. </TD></TR></TABLE>
Then you're looking for just an Eye Bolt?
you are dealing with a clevis joint and you need a solid rod end a.k.a. crappy heim joint
the first item on this page
http://www.swracecars.com/shop...+Ends
I leave it up to you to find the right size etc
they can also be called solid rod eye's instead of ends
kos99ngel
24
Apr 9, 2008 09:25 PM
spaceman00
Apr 21, 2007 11:09 PM
crx_ef8
Jun 26, 2003 12:25 AM
