Which Primary O2 sensor - B16A EG6
Old Dec 26, 2007 | 03:16 PM
Mohsin's Avatar
Default Which Primary O2 sensor - B16A EG6
Hi All,
Just looking for a replacement primary o2 sensor for my B16a EG6, But there are two possibilities from denso:
#234-4099 - (Del sol b16a2)
#234-4011 (listed under b16a2 - civic si)
Which one should i buy?
Thanks!
Old Dec 26, 2007 | 03:51 PM
Mohsin's Avatar
Default Re: Which Primary O2 sensor - B16A EG6 (Mohsin)
bump which do i need?
Old Dec 26, 2007 | 04:10 PM
NOman0608's Avatar
is your wiring harness OBD1 or OBD2?
Old Dec 26, 2007 | 04:13 PM
Mohsin's Avatar
Default Re: Which Primary O2 sensor - B16A EG6 (NOman0608)
obd1 - 93EG6
Old Dec 26, 2007 | 05:02 PM
92eghatchvx's Avatar
get the del sol one its obd1 man
Old Dec 26, 2007 | 05:03 PM
Powered by VTEC's Avatar
Default Re: Which Primary O2 sensor - B16A EG6 (92eghatchvx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92eghatchvx &raquo;</TD></TR><TR><TD CLASS="quote">get the del sol one its obd1 man </TD></TR></TABLE>
thats what i will get too..they are 4 wires,right ?
Old Dec 27, 2007 | 02:32 AM
Mohsin's Avatar
on denso's site it says both can be used for b16a's. I just got an email from one of the distributors and he said the 4011 is longer? and thats the difference?
Old Dec 27, 2007 | 06:55 AM
NOman0608's Avatar
Yes, Get the OBD1 Del Sol.
Old Dec 27, 2007 | 07:25 AM
95jdmcivic's Avatar
If your using your same civic wiring harness, then you need the O2 for your civic, but if your not, you need the o2 for which ever harness your using.
Old Dec 27, 2007 | 07:45 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: (95jdmcivic)
^^^He's right^^^
The O2 sensors I believe are identical, it's the connectors that are different.
Old Dec 27, 2007 | 08:08 AM
Mohsin's Avatar
because my car is a JDM eg6 it has a b16a in it but on denso's site they dont have that application because the US never had a b16 in a civic between 92-95.
Old Dec 27, 2007 | 08:22 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: (Mohsin)
Get one that's meant for a 94-95 Del Sol w/B16A3.
Old Dec 27, 2007 | 08:58 AM
thisisntjared's Avatar
Default Re: (mcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">^^^He's right^^^
The O2 sensors I believe are identical, it's the connectors that are different.</TD></TR></TABLE>thats my understanding too. a 4 wire is a 4 wire. for civics they are the same between obdI and obdII....
Old Dec 27, 2007 | 09:55 AM
Mohsin's Avatar
Default Re: (thisisntjared)
so both parts are identical then but the 4011 being quite a bit more expensive.
Old Dec 27, 2007 | 11:54 AM
BryanM.'s Avatar
Resident Gearhead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">Get one that's meant for a 94-95 Del Sol w/B16A3.</TD></TR></TABLE>
An OBDI sensor itself is identical to an OBDII unit, it's the connector that's different.
When I got my OBDI JDM B16A the O2 sensor was bad. I got one for a ^^^ 94-95 Del Sol w/B16A3 and haven't had an issue in 6 years.
I've also posted in your other thread, make sure it's the O2 that's bad.
GL
Old Dec 27, 2007 | 01:24 PM
Mohsin's Avatar
thanks mcvtec, i just went out for a drive and withit fully warmed up it bogs from the line and theres that little lag before it fully gets going. Once over 3.1K its fine even when warm.
Old Dec 28, 2007 | 09:04 AM
BryanM.'s Avatar
Resident Gearhead
I made a small error:
93-95 Del Sol w/B16A3
Not a big deal but missing details bugs me.
ryanangelo212
Mar 1, 2011 06:19 PM
bigizsosexy
Jul 1, 2008 11:30 AM
CrxEDguY
Apr 28, 2005 12:34 PM
94b16delslow
16
Feb 6, 2005 08:15 PM
integranator
Jul 27, 2003 03:49 PM
