Help! Bolt snapped off on rear toe adjuster
Old Dec 26, 2007 | 03:15 PM
sloweh3's Avatar
Default Help! Bolt snapped off on rear toe adjuster
Ok, I just had my 93 ex aligned today. Well, they were trying to get the bolt loose to adjust rear toe, the head of the bolt snapped out. How hard is going to be to get this bolt out so I can get new arms? The nut on the inside of the frame is all rounded, so it's not like a normal nut you can get a socket or wrench on. I'm pretty stumped right now, so any help is appreciated. Thanks.
Old Dec 26, 2007 | 03:20 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Help! Bolt snapped off on rear toe adjuster (sloweh3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloweh3 &raquo;</TD></TR><TR><TD CLASS="quote">Ok, I just had my 93 ex aligned today. Well, they were trying to get the bolt loose to adjust rear toe, the head of the bolt snapped out. How hard is going to be to get this bolt out so I can get new arms? The nut on the inside of the frame is all rounded, so it's not like a normal nut you can get a socket or wrench on. I'm pretty stumped right now, so any help is appreciated. Thanks.</TD></TR></TABLE>
The nut inside the frame is rounded, but has 2 tabs where it holds itself onto the chassis. It has a slot that it slides on. I'm assuming you allready cut into the chassis to get at the nut.
Your life is going to suck, man...lol sorry. You're going to have to manhandle it out of there somehow. Cut the toe adjuster off. Do this by cutting thru the bolt and bushing. Then it's all drilling, smashing, torching, and grabbing. Be creative.
Old Dec 26, 2007 | 04:24 PM
sloweh3's Avatar
Default Re: Help! Bolt snapped off on rear toe adjuster (B serious)
yea, i kinda figured that. i was seeing if anyone had an easier way to do it... thanks though
Old Dec 26, 2007 | 08:30 PM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
I was lucky the nut welded to the frame snapped of when they was adjusting it. Damn alignment guy made me cut my frame to get the nut out. Oh an i had to cut the bolt that holds the toe arm GRRR. Try to use a strong flat head with a hammer, hit the crap out of it! So the welds can break.
Old Dec 26, 2007 | 08:36 PM
sloweh3's Avatar
Default Re: (phyzJunkieCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phyzJunkieCivic &raquo;</TD></TR><TR><TD CLASS="quote">I was lucky the nut welded to the frame snapped of when they was adjusting it. Damn alignment guy made me cut my frame to get the nut out. Oh an i had to cut the bolt that holds the toe arm GRRR. Try to use a strong flat head with a hammer, hit the crap out of it! So the welds can break.
yea, i know it's gonna be a bitch. i'm just trying to figure out how to get that welded nut off, because of the metal bracket in front of it. i'm thinking of trying to get all of it off with an air chisel and buy a set of aftermarket toe adjuster links.
this damn car is turning out to be more of a pain in the *** than i expected
Old Dec 26, 2007 | 08:44 PM
air chisel will work.
Old Dec 26, 2007 | 08:56 PM
sloweh3's Avatar
yea, i guess i'm gonna buy some aftermarket arms, put a new bolt/nut on after i get it chiseled out. sucks because i don't have access to a garage until next sunday to mess with it
Old Dec 27, 2007 | 01:45 PM
sloweh3's Avatar
Default Re: (sloweh3)
i ordered a set of aftermarket rear toe arms. once they come in, hopefully it won't be too much of a pita to get the old welded nuts off
Old Dec 27, 2007 | 02:35 PM
B serious's Avatar
The nut inside the frame is NOT welded. It slides on a slot. If you pound the stub of the cut off bolt towards the front of the car, you should be able to pop the slotted nut out of it's track. Dont bend the frame when doing this.
Old Dec 27, 2007 | 03:30 PM
sloweh3's Avatar
Default Re: (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">The nut inside the frame is NOT welded. It slides on a slot. If you pound the stub of the cut off bolt towards the front of the car, you should be able to pop the slotted nut out of it's track. Dont bend the frame when doing this. </TD></TR></TABLE>
ok, thanks
Old Jan 4, 2008 | 06:31 PM
sloweh3's Avatar
update: i got everything taken care of. since the guy snapped the bolt off, i didn't have to pay for any labor. picked up a set of aftermarket toe arms for it, and got the shop to put everything on. now i'm waiting to have my roomate take it up to his work and get the subframe rewelded
slateEKsi
May 23, 2010 06:18 PM
civicdelsol33
Suspension & Brakes
Dec 17, 2007 09:45 AM
onemoreday21
Jul 2, 2005 08:55 PM
B18G
Jan 6, 2004 08:48 PM
CivicEK.PDX
Sep 12, 2002 06:42 PM
