ls vtec drilling oil feed ?
Old Dec 26, 2007 | 02:47 PM
deadfish13's Avatar
Default ls vtec drilling oil feed ?
saw in a thread a guy saying he modified the block to have an internal oil feed line like in the b16a and b18c
my questions ?
how does the oil feed work in the vtec engines ..b16a b18c ? where is the oil coming from ?
can a hole actually be drilled in the same area on the non vtec blocks or do the b18b and b20b block cast too differently to make this impossible?
thanks for the replies
happy new year
Old Dec 26, 2007 | 03:29 PM
CerealKiller's Avatar
Default Re: ls vtec drilling oil feed ? (deadfish13)
No drilling required, Just buy a GE vtec conversion kit. Comes with everything you need to turn your head into vtec.
Old Dec 27, 2007 | 04:40 PM
deadfish13's Avatar
Default Re: ls vtec drilling oil feed ? (CerealKiller)
i know about the ge kit ....i have one.
was jus curious about the possibility of drilling
dont know how many dude would ACTUALLY take a drill press to a block !!! lol
anyone have any more info or thoughts on the whole idea ?
Old Dec 27, 2007 | 06:17 PM
girliehonda's Avatar
follow the instruction that come with the GE kit.
if the dowel pins sit good then you dont need to drill anything.
good luck
Old Dec 29, 2007 | 12:28 PM
deadfish13's Avatar
Default Re: ls vtec drilling oil feed ? (girliehonda)
maybe i should explain this more .
lol je kit comes with the dowels i know.
i am not asking about doing it ...i dont enough research to know .
this is just my observation and curiousity
try to explain once more
b18c b16a have an oil port in the block takes oil from the block up to the head.
b18b b20's DONT have this port.
my question can this port be drilled and if not ...why.
i'll make some diagrams
Old Dec 29, 2007 | 12:51 PM
DonF's Avatar
NO. There is NO material on the block to do this. Stick a VTEC gasket on your block and you will notice that you drill into air.
Old Dec 29, 2007 | 08:07 PM
serio_ENDLESS's Avatar
i say it cant be done or they would have said something to us about but it does the same thing a ge conv. kit would do
just my $.02
Old Dec 31, 2007 | 09:18 AM
deadfish13's Avatar
Default Re: ls vtec drilling oil feed ? (DonF)
lol
thanks donf
my friend actually showed me this ...after he laughed at the idea .
apparently he thought the same thing couple yrs back .
oh well ...
thanks again to donf
maddcrx
Jul 5, 2008 01:09 PM
libral00
Mar 30, 2008 09:57 AM
c-y-nickel
Nov 4, 2003 02:11 AM
dAndOg130
Nov 4, 2003 02:09 AM
drumking15
May 14, 2003 10:06 AM
