I need a Pinout Tool!
Old Dec 26, 2007 | 02:20 PM
RYNO48's Avatar
Default I need a Pinout Tool!
Does anyone know where you can find one of these. I've searched the web and HT and very few people know what i'm talking about and no one knows where to get it. I already have the Skunk2 jumper harness but the smog referee is being a &^% and is saying i got to straight wire it.
This tool slides into the wireharness blocks allowing you to remove the wires with the connections intacted.
Any help would be appreciated.
Old Dec 26, 2007 | 03:04 PM
ekb16's Avatar
i use a paperclip, bent it straight, and file the end like a flat head...worked great for me
Old Dec 26, 2007 | 03:09 PM
RYNO48's Avatar
Default Re: (ekb16)
I started with a peace of wire that i hammered flat then shaped to fit it. It worked but not nearly good enough to do like 50-60 wires with. I guess I'll start with something a little thinner and see what happens. thanks
Old Dec 26, 2007 | 03:12 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (RYNO48)
hasport used to have them, you may still be able to get them,
the big tool guys have them but they are usually in a set.
Old Dec 26, 2007 | 04:32 PM
RYNO48's Avatar
Default Re: (boostedcivicsir)
I called Hasport and they got theres but none for anyone else and the snap on website is "*** on a stick"
Old Dec 27, 2007 | 12:07 AM
toyomatt84's Avatar
Sanji
I use Molex Pinout tools.
http://www.svc.com/sleeving-tools.html
Old Dec 27, 2007 | 05:37 AM
gibsanez's Avatar
Default Re: (toyomatt84)
Just go buy one of those precision screw driver sets, those small 6 piece watch screwdriver sets, and use the smallest one I got my whole set for $6 from the local hardware store
Old Dec 27, 2007 | 12:20 PM
RYNO48's Avatar
Thanks for the link, but i can't get the pics to enlarge so i can see which one it is. If they are indeed the tool it looks like it would be the Female remover right.?
Old Dec 27, 2007 | 01:43 PM
toyomatt84's Avatar
Sanji
Just get the Sunbeam kit:
It'll contain most everything you could need.
Old Dec 30, 2007 | 02:31 PM
RYNO48's Avatar
Well, thanks for all the info guys. I got it done. It took longer than i would have liked but this kind of stuff always does.
So, the final solution. One precision screw driver (ground down to make it even smaller) and a second set of hands (60 yr old dad) pulling the wire out of the back while i held the block in one hand and pushed the clip down with the other.
Result. Completely repinned to 99-00 Ecu no codes and ready for that smog ref. *****!
alexpr
Oct 25, 2012 08:16 PM
laziebun
Audio / Security / Video
Mar 7, 2010 04:32 PM
rdssk8rcs1
Feb 13, 2009 06:12 AM
qp
Apr 26, 2005 11:33 AM
Mikey3000
Jul 7, 2002 04:53 AM
