tire vibrates
when taking off from dead stop the front tires vibrate or move back an forth real crazy is that normal because my duddy's car does the same, oh and just wanted to throw this in when driving when i hit bumps a here like a clacking noise from left front suspensoin but it is not strut problem
it could be a warn out tie rod, jack up the front end and wiggle your tires, they should'nt move back and forth. make sure everythings tight on the front end.
if you cant figure it out, take it to an allignment shop, they will tell you whats wrong, most likely.
sounds like your tires are not balanced...check with a local tire shop and if they are then see if your tire will wiggle bad back and forth when it's up in the air. If so you're probaby going to need new wheel bearings....If all of the above isn't the problem then I'd suggest getting some hub centric rings.
why dont you figure out if its the wheel bearings first before spending money on things you might not need.. and you didnt mention you had aftermarket wheels.
mikeunreal2
Mar 1, 2006 02:21 PM
