Finally! 8 o ate + 237.3whp= a car that runs!
I finally finished my new motor setup and got to tune it. Keep in mind this is a street car, not a full out race car
Big thanks to Method Motorworks and Revspeed for the "Soy Sauce"
I know there is more power in this motor if I get a new header and fix a couple little issues. but 237.3 on a DynoJet 248 with no VSS and a restricting header aint bad for a street car. Im just REAL happy with the car and how it feels, very strong through the entire band.
Setup:
• Block: B18C1
• 84.5mm Darton MID Sleeves
• 11.8:1 Arias Pistons
• Eagle Rods
• ARP head studs
• B16A2 Head
• Portflow Port & polish.
• Multi-angle valve job
• Bronze valve guides
• Ferrea Valves
• BC4 Cams
• Pro-Fab Exhaust manifolD
• Stock ITR Intake Manifold
• RC 440cc injectors
• Hondata s200
Graph:
Pics of the car for reference (dont mind the dirty status, its been sitting for a year and a half!)
Engine Shot (Dont hate on the Wiggins blue tape series! HAHA)
Setup:
• Block: B18C1
• Eagle Rods
• ARP head studs
• B16A2 Head
• Ferrea Valves
• BC4 Cams
• Hondata s200
Graph:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption »</TD></TR><TR><TD CLASS="quote">Is this just another post/thread with the intent of selling the magical "soy sauce" ? If not, post what the fuel cocktail is. Otherwise, i vote this thread should be locked.</TD></TR></TABLE>
I vote that you should STFU, this is a thread to post what numbers I made as a result of my long time running build. I dont know the cocktail, or wont pretend to know it. If you want to know what he does with his "Soy Sauce", then make a thread or PM Revspeed, dont ruin mine...thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H8 O ATE »</TD></TR><TR><TD CLASS="quote">
yeah ***.. lol
dope numbers man. car and numbers are looking dope..
</TD></TR></TABLE>yeah ***.. lol
It's Xmas don't let that other thread ruin the info in this one.
OP, those are some very good numbers and a reasonably simple build.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption »</TD></TR><TR><TD CLASS="quote">There was already a thread or 2 created and subsequently locked due to this secretive fuel. Those are good numbers, but did you see what the motor does without the extra oxidizer?</TD></TR></TABLE>
yes, it was about 225+
yes, it was about 225+</TD></TR></TABLE>
Good #'s. Didnt mean to jump on the thread, but if you read through the other two, it really got quite annoying. Youre setup made good power off "the sauce" so its a little more tolerable here.
Understandable. I know the last 2 threads were hard to read and got out of hand. The OP is the guy that tuned this car. So I know he is very secretive, but does a good job.
the 225whp run was through the muffler with soysauce
on 91 the best run was 209whp on open headers
237 whp is on open headers
this setup ran out of injectors
this car will make over 240+
i didn t even get to adjust the cam gears yet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">so basically, it makes 210whp on pump, what i'm guessing you will be using 9 times outta 10.
go to the track.
not true, It made 210 on 91. This car doesnt get driven much, so the times it will be running...9 out of 10 it will be running on either the special mixture or race gas. So 237 will be the normal driving around HP. I might take it to the track once, or twice. But like I said before. This is a street car, meant for the streets
go to the track.
</TD></TR></TABLE>not true, It made 210 on 91. This car doesnt get driven much, so the times it will be running...9 out of 10 it will be running on either the special mixture or race gas. So 237 will be the normal driving around HP. I might take it to the track once, or twice. But like I said before. This is a street car, meant for the streets
This car doesnt get driven much, </TD></TR></TABLE>
This is a street car, meant for the streets </TD></TR></TABLE>
so the times it will be running...9 out of 10 it will be running on either the special mixture or race gas. </TD></TR></TABLE>
I might take it to the track once, or twice. </TD></TR></TABLE>
interesting.....so it's a street car that runs on race gas all the time? Doesn't sound very economical.
a setup like that should be making more than 210 on pump .. maybe u should try a different intake setup and watch it get 237 on pump instead of soy sauce .. then who knows what it ll make with that soy sauce
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacK_Dc4 »</TD></TR><TR><TD CLASS="quote">a setup like that should be making more than 210 on pump .. maybe u should try a different intake setup and watch it get 237 on pump instead of soy sauce .. then who knows what it ll make with that soy sauce
why should it make more than 210? because you have seen other dyno's that are higher?
</TD></TR></TABLE>why should it make more than 210? because you have seen other dyno's that are higher?
I plan on it, this car is far from done. Money is running tight so getting it running smooth with the current setup is my 1st priority.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR »</TD></TR><TR><TD CLASS="quote">
interesting.....so it's a street car that runs on race gas all the time? Doesn't sound very economical.</TD></TR></TABLE>
I think you are confusing Street car with a Daily driven car. The car is not meant to be a full drag car built for the track. This is my fun "weekend" car. Where it will probably use 5 gallons a week (at most) wont break the bank. And since when did this hobby become economical?
</TD></TR></TABLE>I plan on it, this car is far from done. Money is running tight so getting it running smooth with the current setup is my 1st priority.
congrats bobby its about fawken time (u need to take me for a ride)
tom was tunning this car w/no intake piping LOL i think u could of made a few more hp
when he made the first pass your motor put down 140ish hp and 128 tq i was like wtf
than i had to check the timing but MR H said it was good (your timming was like at 12
but 237 w/ a blend of hoisin and teriyaki sauce very nice
p.s just wait till we put the hoisin and teriyaka sauce on my k24 motor
CONGRATS
JOSH
CONGRATS
JOSH
hells yea josh, I would of been pissed if it was 140! haha This bitch is fun as hell to drive! I know it aint no full race gutted K series Eg, but we aint all as rich as you josh! haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM JEFFREY »</TD></TR><TR><TD CLASS="quote">what know more ITBS?</TD></TR></TABLE>
TWM's were apain in the ***, would make just as much power on a ported intake mani n tb, plus i wanted the reliability. Maybe down the road I will get some todas or something else, but no TWM!
When you commin to the No jeff?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H8 O ATE »</TD></TR><TR><TD CLASS="quote">TWM's were apain in the ***, would make just as much power on a ported intake mani n tb, plus i wanted the reliability. Maybe down the road I will get some todas or something else, but no TWM!
When you commin to the No jeff?</TD></TR></TABLE>
ITB's have serious potential. But TWM's are just not where its at. Once you get over the bling/sound factor, its a bit dissapointing, isnt it?
When you commin to the No jeff?</TD></TR></TABLE>ITB's have serious potential. But TWM's are just not where its at. Once you get over the bling/sound factor, its a bit dissapointing, isnt it?
