Honda accord 2000 LX wont start
Old Dec 26, 2007 | 05:09 AM
chris28's Avatar
Default Honda accord 2000 LX wont start
I have a 2000 Honda accord when I went to start it this morning it makes a clicking noise comming from the hood the lights flicker and eventually come on but the car dont start and that clicking noise? the lights seem to come on slowly but they do work. And The more i turn the key i only get that clicking noiseE???
HElppppp
Old Dec 26, 2007 | 06:49 AM
lightningd's Avatar
Default Re: Honda accord 2000 LX wont start (chris28)
probably starter not having enough juice? i'd go ahead and check the battery with a meter, or if you're completely non-mechanical, find a friend that can check for you. also, if you can jump it, and it runs fine, then most likely it is the battery.
oh, also, if your terminals on the battery are loose or have a bad connection this can happen too.
Old Dec 26, 2007 | 08:03 AM
Heat's Avatar
Jump the car and take it to Autozone, they'll check your battery out at no cost.
My uneducated guess is that your battery needs a charge, or is dead. Is this the original battery with the car? If so it's really due to be replaced.
Old Dec 26, 2007 | 12:36 PM
accord99power's Avatar
Default Re: Honda accord 2000 LX wont start (Heat)
agreed its your battery man.
Old Dec 26, 2007 | 03:34 PM
lightningd's Avatar
ah yes a 2000, if the battery lasted this long that's actually really good. by phenomena of acid, a battery only lasts 5-6 years.
Old Dec 27, 2007 | 04:39 AM
chris28's Avatar
thanks guys it was the battery now i just have to have it tested and see if it needs to be replaced but with a jump it started right up
Old Dec 27, 2007 | 12:05 PM
Default Re: (chris28)
like previously posted go to autozone or auto places that will test for free. Check water level if its not a serviceless battery. fill with distilled water only.
rvirene
Apr 23, 2017 04:44 AM
AZ-Accord
Sep 13, 2012 01:01 AM
JudgeWest
Jun 29, 2011 10:08 PM
crdean1
Jan 6, 2011 08:36 AM
ssmdhondadriver
Aug 18, 2010 03:44 AM
