what are the differences between Brembo and Autozone rotors
Old Dec 26, 2007 | 03:05 AM
dc2long's Avatar
Default what are the differences between Brembo and Autozone rotors
what are the diffrences between Brembo Blanks and Autozone Rotors? <-- noob question. Are the Brembo Blanks bigger than autozones? i can get the brembo blanks for 70 bucks a pair and i think the autozones should be 17 each rotor.
which do you guys recommend for a daily driver? is it worth paying the extra 30 bucks for the brembo?
its for a 97 gsr
tia
Old Dec 26, 2007 | 05:38 AM
jhammond_82's Avatar
Reject Papi
Default Re: what are the differences between Brembo and Autozone rotors (dc2long)
autozone rotors, huh... i would have to say anything that my life is in the hands of, i would want the better quality, and reliability, reguardless of how much it costs me.
Old Dec 26, 2007 | 06:32 AM
Riake's Avatar
Default Re: what are the differences between Brembo and Autozone rotors (jhammond_82)
Make this thread in the RR/AX forum if you want more replies.
A lot of the people in there use Autozone blanks, because to many, the rotors are a wear item that need to be replaced frequently.
Old Dec 26, 2007 | 07:14 AM
Padawan's Avatar
Darth ModerVader
Functionally, you really won't notice a difference between the two. I'd go with Duralast / AutoZone. They're less expensive and even have a replacement warranty.
Old Dec 26, 2007 | 12:17 PM
racebum's Avatar
Default Re: what are the differences between Brembo and Autozone rotors (Padawan)
As long as it's a decent grade of iron, shop for price. I know the Joe's stores had been selling some pretty low quality rotors that didn't last long. Like the above posts have said, rotors wear out. I think you can get a set of 4 Brembo blanks on ebay for 129ish
Old Dec 26, 2007 | 02:09 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: what are the differences between Brembo and Autozone rotors (idrivesideways)
+1 for autozone/duralast for street/everyday use
Old Dec 26, 2007 | 03:35 PM
dc2long's Avatar
Default Re: what are the differences between Brembo and Autozone rotors (GRAF-FITI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Riake &raquo;</TD></TR><TR><TD CLASS="quote">Functionally, you really won't notice a difference between the two. I'd go with Duralast / AutoZone. They're less expensive and even have a replacement warranty </TD></TR></TABLE>
thats what i was thinking. i would prbably be replacing my rotors everytime i change new pads.
just wanted to know if there was anything i should be worrying about.
thanks guys
Old Dec 26, 2007 | 03:40 PM
96 GSR-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idrivesideways &raquo;</TD></TR><TR><TD CLASS="quote">As long as it's a decent grade of iron, shop for price. I know the Joe's stores had been selling some pretty low quality rotors that didn't last long. Like the above posts have said, rotors wear out. I think you can get a set of 4 Brembo blanks on ebay for 129ish</TD></TR></TABLE>
most of the egay blanks are fakes.....fyi
Old Dec 26, 2007 | 05:08 PM
all-mtr-teg's Avatar
It was weird cause when I use to work for autozone, every now and then I would receive some Brembo rotors with my shipment mixed in with the autozone brand "Duralast" brake rotors. I use their $15 rotors on my gsr's and for daily driving i can't tell the difference from oem and autozone brand.
Old Dec 26, 2007 | 06:54 PM
CubanLynx84's Avatar
Default Re: what are the differences between Brembo and Autozone rotors (all-mtr-teg)
i have the brembo blanks with hawk hp pads and ss lines the car stops on a dime for me.
Old Dec 26, 2007 | 07:01 PM
dc2long's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">It was weird cause when I use to work for autozone, every now and then I would receive some Brembo rotors with my shipment mixed in with the autozone brand "Duralast" brake rotors. I use their $15 rotors on my gsr's and for daily driving i can't tell the difference from oem and autozone brand.</TD></TR></TABLE>
which ones are the $15 rotors? are these the duralast?
Old Dec 26, 2007 | 07:04 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2long &raquo;</TD></TR><TR><TD CLASS="quote">which ones are the $15 rotors? are these the duralast?</TD></TR></TABLE>
Yes, though I think they've raised the pricing slightly.
Old Dec 26, 2007 | 07:07 PM
dc2long's Avatar
i think they also have valuecraft. is this also an autozone brand and recommendable?
Old Dec 26, 2007 | 07:26 PM
Padawan's Avatar
Darth ModerVader
The Valucrafts are cheaper, but only have a 1 year warranty vs. the Duralasts 2 year warranty. Either should be fine, though the ones that most folks typically go with are the Duralasts. I've also read that some stores only stock the Duralasts and need to special-order the Valucrafts.
Old Dec 26, 2007 | 08:11 PM
PrinceAli132's Avatar
Search for autozone rotors especially in the roadrace/auto-x forum. But here are two links
https://honda-tech.com/zerothread?id=181691 - The OP edited his post and removed his info but there are still good comments.
https://honda-tech.com/zerothread?id=779391
I did come across another thread in the roadrace and auto-x thread but don't have the link but it did show that different rotors have different weights. I believe OEM was the heaviest then brembo then autozone.
Honestly, Ive been using autozone rotors for 3 years now on and off the track with no problems.
Autzone rotors
Ali
Old Dec 26, 2007 | 08:28 PM
I would always get them w/ a discount so they were around $15 a piece a few years ago, maybe around $20 or more now. But yeah the Duralast seemed heavier than the valucraft. I always buy the Duralast which are a little more than the valuecraft brand.
Old Dec 27, 2007 | 06:22 AM
Koyoloeor's Avatar
Go for the autozone, good price and they do stand behind them if they expletive up
Old Dec 27, 2007 | 09:42 AM
Riake's Avatar
Default Re: what are the differences between Brembo and Autozone rotors (PrinceAli132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">
Wouldn't someone want to have a heavy rotor? I mean yeah it is unsprung weight but the difference should be minimal in that department. What I am saying is it would be harder for the heavy rotor to get up to temperature for the pads, but once it gets there it will have an easier time staying there (if they are all the same material). Of course everything is up to a point. Probably wouldn't make a difference either way though.
Old Dec 27, 2007 | 11:51 AM
[ iLL ] iNt3GrA's Avatar
Default Re: what are the differences between Brembo and Autozone rotors (Koyoloeor)
dont buy the valuecrap rotors, they look like **** compared to the duralast.
Old Dec 27, 2007 | 11:58 AM
Default Re: what are the differences between Brembo and Autozone rotors (Riake)
Wouldn't someone want to have a heavy rotor? I mean yeah it is unsprung weight but the difference should be minimal in that department. What I am saying is it would be harder for the heavy rotor to get up to temperature for the pads,Probably wouldn't make a difference either way though.</TD></TR></TABLE>
A few have made that arguement in the RR/Auto-X section, from when I did some searching a while ago.
Ali
Old Dec 27, 2007 | 03:06 PM
dc2long's Avatar
i guess autozone raised their prices up to 29 each rotor with a 2 year warranty. I might just go for brembos (a name you can trust) for 70 for 2 front rotors from https://honda-tech.com/zerothread?id=1411597. thanks for everyones help
i hope the PBR pads are good.
Old Dec 27, 2007 | 03:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2long &raquo;</TD></TR><TR><TD CLASS="quote">I might just go for brembos (a name you can trust) </TD></TR></TABLE>
First off, you obviously don't realize that many people trust Autozone rotors, not only on the street but on track as well.
Secondly, its not just a $10 differene. Because the autozone's come with a warranty. So when your rotors get chewed up from street/track use you can just take them back and get a replacement set for free.
So two sets of autozone rotos for $60 &gt; 1 pair of brembo rotors for $70.
Ali
Old Dec 27, 2007 | 03:22 PM
dc2long's Avatar
Ali</TD></TR></TABLE>
good point
Old Dec 27, 2007 | 03:28 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
autozone rotors come with a 2 year replacement warranty.
Brembo blanks are made with a slightly better process and materials.
candy eg
Oct 21, 2006 06:25 PM
ComCool
Feb 24, 2005 07:34 AM
JHD_DA
Aug 12, 2004 06:40 AM
patastinky
Jul 8, 2004 12:01 PM
hb_racer
Apr 14, 2002 08:55 AM
