Who makes Valve Spings fro NON -Vtec head? (H23)
Old Jun 28, 2002 | 10:21 AM
BluLuder's Avatar
Default Who makes Valve Spings fro NON -Vtec head? (H23)
I already looked under Eibach, Crower & Ferrea.
any suggestions?
Old Jun 28, 2002 | 10:34 AM
JG Luder's Avatar
Default Re: Who makes Valve Spings fro NON -Vtec head? (BluLuder)
http://www.JGenginedynamics.com
Old Jun 28, 2002 | 02:36 PM
2point6's Avatar
Default Re: Who makes Valve Spings fro NON -Vtec head? (Todd 94)
Web Cams
Old Jun 28, 2002 | 07:04 PM
str8rcn's Avatar
Default Re: Who makes Valve Spings fro NON -Vtec head? (2point6)
I have tried all of these places with no luck and have been looking for 2 years.If you do find any please post here.Valve springs are the only stock part left in my motor.
Old Jun 29, 2002 | 07:36 AM
JG Luder's Avatar
Default Re: Who makes Valve Spings fro NON -Vtec head? (str8rcn)
JG does have them. They put them on their Head packages.
Old Jun 30, 2002 | 12:03 PM
BluLuder's Avatar
sweet, too bad you cant get past JG's initial home page.
but I will give em a ring. You know how much they usually run?
Old Jun 30, 2002 | 02:32 PM
Si4WS's Avatar
Web Cams
As far as I can tell they are out of business. Web site is gone and Ph numbers disconnected.
Old Jul 1, 2002 | 08:24 AM
symba's Avatar
this is at the jg website:
Prelude H23 Street and race heads. Pro Series and Redline series
Street strip heads including pocket bowl porting, comp valve job, new valve stem seals, resurfaced or milled up to .040, hot tanked and cleaned, modify valve guides for high lift cams . $750.00
Redline Series heads including full port and polish, comp valve job, new valve stem seals, comp springs, T 7075 aluminum retainers, resurfaced or milled up to .040, hot tanked and cleaned, swirl polished stock valves,modified valve guides for high lift cams, polished chambers. $1150.00
Pro Series Heads including full port and polish, comp valve job, new valve stem seals, resurfaced or milled up to .040, hot tanked and cleaned, T7075 aluminum retainers, comp valve springs, new valve stem seals,modified valve guides for high lift cams, polished chambers, over size stainless steel intake and exhaust valves. $1400.00
Welded combustion chambers add $150.00
Combustion chamber unshrowding
Old Jul 1, 2002 | 09:00 AM
BluLuder's Avatar
Default Re: Who makes Valve Spings fro NON -Vtec head? (symba)
thanks, but damn I cant get past the JG main page!
I need to call em up to get prices on just valve springs and retainers..
Old Jul 1, 2002 | 10:50 AM
2point6's Avatar
Default Re: Who makes Valve Spings fro NON -Vtec head? (Si4WS)
Web Cams
They are still open, did business with them this morning. try http://www.webcamshafts.com
or http://www.webcaminc.net
[Modified by 2point6, 7:53 PM 7/1/2002]
Old Jul 1, 2002 | 11:18 AM
JG Luder's Avatar
http://www.webcaminc.net... they changed websites. Tripped me out for a bit too. They may have them, but they aren't listed on the site.
JG Engine Dynamics:
626-281-5326
WebCam:
909-369-5144
Good luck, when I called it was busy.
Old Jul 1, 2002 | 05:05 PM
BluLuder's Avatar
no anwer from Web Cam, I didnt see them in the dealer catalog nor on their page.
but if you get a hold of them before I do, hit me up with a part # for springs and retainers! thanks
Old Jul 2, 2002 | 07:55 PM
kidkutz's Avatar
you can buy blanks and have them custom made for your car
Old Jul 3, 2002 | 05:32 AM
BluLuder's Avatar
Default Re: Who makes Valve Spings fro NON -Vtec head? (kidkutz)
hmm, maybe I can send in these stock ones then?
Old Jul 3, 2002 | 05:37 AM
JG Luder's Avatar
blank springs and have them made stiffer? Exactly how is this done?
Old Jul 3, 2002 | 07:29 AM
LudEcrous's Avatar
call portflow.. www.portflow.com
see if they can suggest anything.
[Modified by LudEcrous, 10:30 AM 7/3/2002]
Old Jul 3, 2002 | 03:21 PM
SilverLudeSi's Avatar
New User
Default Re: Who makes Valve Spings fro NON -Vtec head? (LudEcrous)
My h23 head is at portflow right now. They said they were going to try to make some shims so they could fit springs for another car or something. Last time I talked to them, they were still looking for something that would work, but that was a few days ago.
Old Jul 8, 2002 | 02:35 PM
BluLuder's Avatar
Default Re: Who makes Valve Spings fro NON -Vtec head? (SilverLudeSi)
Still NO LUCK! My shop doesnt want to deal with JG for some reason and Web Cam said they dont make them for my H23
and R&D said to make custom springs to get them measurements and in 2 months I could have something. *thats too long.
Man, someone has too know another place where I can straight buy some higher revving valve springs for my car.
[Modified by BluLuder, 5:36 PM 7/8/2002]
Old Jul 8, 2002 | 03:00 PM
Si4WS's Avatar
Did you try Gude?
just_stock
May 3, 2024 02:23 PM
prelude beast
Mar 11, 2006 12:15 PM
92LudeSI
Dec 16, 2003 03:47 PM
ludesleep
Jun 3, 2003 01:41 AM
