turn signals won't turn off
Old Dec 25, 2007 | 06:58 PM
JDM_95_LS's Avatar
Default turn signals won't turn off
I've got a 95 integra ls and a couple of days ago my cluster just died out on me while i was driving it turned back on itself in 5 minutes. so i didn't drive it for a couple of days and took out the battery and when i plug in the battery back in the cluster lights stays on all the time.
Old Dec 25, 2007 | 07:56 PM
JDM_95_LS's Avatar
Default Re: turn signals won't turn off (JDM_95_LS)
bump.. i need this fix before friday
Old Dec 25, 2007 | 07:59 PM
JDM_CRX_PLEASE's Avatar
bump for integra help!
Old Dec 25, 2007 | 11:18 PM
JDM_95_LS's Avatar
Default Re: (JDM_CRX_PLEASE)
thanks. bump
Old Dec 25, 2007 | 11:21 PM
tweek_boii's Avatar
Default Re: (JDM_95_LS)
IM A NOOB. WHAT IS BUMP
I HAVE PROBLE MY CLUSTER TURNED ON ONCE ON FREEWAY AND TURNED OFF I NEE HELP TO KEEP IT ON , IT HASNT EVER TURNED BACK ON B.U.M.P
Old Dec 26, 2007 | 02:48 AM
northemt88's Avatar
Are your hazards on???
Pull your cluster and check all th pulls in the back, Check your actual hazard switch also...
And a bump is used to keep a page alive and at the top of the list to hopefully get help
Old Dec 26, 2007 | 08:45 AM
JDM_95_LS's Avatar
Default Re: (northemt88)
i did that already still the same
Old Dec 26, 2007 | 11:33 PM
JDM_95_LS's Avatar
changed the toggle it was fine until couple hours. need help still
Old Dec 26, 2007 | 11:42 PM
7mile's Avatar
it did that to my gsr a while back, are you running anything else? amps? cluster gauges? mines was a cluster gauge, shortage to the wires, had to rewire it over.
could just be a shortage somewhere or a + touching ground..
Old Dec 28, 2007 | 03:54 AM
JDM_95_LS's Avatar
Default Re: (7mile)
checked the amp already it's not touching
rrd5011
Dec 16, 2011 05:30 AM
vtecislove
Jun 2, 2011 12:06 PM
maxwellmercer
Oct 3, 2010 06:36 PM
type-r-eg
Nov 19, 2009 06:38 AM
PHILLLLIIPPPP
Dec 28, 2006 01:27 AM
