HUGE PROBLEM DOES NOT LIGHT UP AT ALL
Old Dec 27, 2007 | 12:08 AM
tweek_boii's Avatar
Default HUGE PROBLEM DOES NOT LIGHT UP AT ALL
okay i just bought my gsr and i notcied that my speed omet and all does not light up. i was in freeway at night and i couldnt see. they turned on in morning bright blue and after 1 minute turned off. i need problem fixed, only things that light up is the numbers for how many miles . my friend says i do not have original set and that i have an aftermarket one here is a pic during the day.
Old Dec 27, 2007 | 12:14 AM
adam081904's Avatar
Default Re: HUGE PROBLEM DOES NOT LIGHT UP AT ALL (tweek_boii)
Your friend is right, Those are not OEM. They are aftermarket. Pull it out and check wiring and relays.
Old Dec 27, 2007 | 12:31 AM
tweek_boii's Avatar
Default Re: HUGE PROBLEM DOES NOT LIGHT UP AT ALL (adam081904)
i pulled it out and wow i dont know what i am looking at and were to check i just dont want to make easy fix hard.
Old Dec 27, 2007 | 01:12 AM
envision's Avatar
might be bulbs cause i dont see how it can just turn off after 1 min. might be wiring too
Old Dec 27, 2007 | 05:30 AM
LSracing94's Avatar
Default Re: (envision)
change the blubs first, they are cheap and its easy
Old Dec 27, 2007 | 06:06 AM
Koyoloeor's Avatar
Default Re: (LSracing94)
just take the aftermarket guage faces off... they should just be taped to the stock guage faces and then see if it lights up. If so then you have a problem with the aftermarket ones
Old Dec 27, 2007 | 11:08 AM
tweek_boii's Avatar
ok ima take it out, take alot of pictures and post them up.
Old Dec 27, 2007 | 12:34 PM
95dc2teg's Avatar
Default Re: (tweek_boii)
they definately look like just covers that go over your original gauges. you can gently slide them off over the needles without takeing on the needle. Just be careful. Your original gauges are under them and they are probably still lighting up fine since those white faced gauges have their own light source. Hopefully they are taped on and not super glued like mine were when i bought the car from some one
Old Dec 27, 2007 | 01:18 PM
Naruto's Avatar
Just a slight observation, but you may want to have your temp gauge needle checked. From the looks of the picture, your car is off, but the temp is up????
Old Dec 27, 2007 | 01:20 PM
StockDC2's Avatar
Default Re: HUGE PROBLEM DOES NOT LIGHT UP AT ALL (Naruto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naruto &raquo;</TD></TR><TR><TD CLASS="quote">Just a slight observation, but you may want to have your temp gauge needle checked. From the looks of the picture, your car is off, but the temp is up????</TD></TR></TABLE>
I think that you're staring at the wrong needle... Temp is on the left.
Old Dec 27, 2007 | 02:29 PM
goodtrouble's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adam081904 &raquo;</TD></TR><TR><TD CLASS="quote">...Pull it out and check wiring and relays. </TD></TR></TABLE>
My brother had those indiglo gauges in his civic and they go out on him sometimes too. I'm pretty sure if your bulbs for your stock gauges aren't dead then it's a wiring problem. IMO I would just revert to the stock gauges and get LEDs to replace your stock bulbs
Old Dec 27, 2007 | 02:43 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Is that a LED windshield nozzle on your cluster trim?
Old Dec 27, 2007 | 04:47 PM
Naruto's Avatar
Default Re: HUGE PROBLEM DOES NOT LIGHT UP AT ALL (StockDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StockDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
I think that you're staring at the wrong needle... Temp is on the left.</TD></TR></TABLE>
ah..yeah you're right LOL...man...been a long day.
Old Dec 27, 2007 | 06:47 PM
loudandlow's Avatar
Default Re: HUGE PROBLEM DOES NOT LIGHT UP AT ALL (CARMA_626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CARMA_626 &raquo;</TD></TR><TR><TD CLASS="quote">Is that a LED windshield nozzle on your cluster trim? </TD></TR></TABLE>
IT SURE IS!!!!
Old Dec 28, 2007 | 06:15 AM
LSracing94's Avatar
Default Re: HUGE PROBLEM DOES NOT LIGHT UP AT ALL (loudandlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudandlow &raquo;</TD></TR><TR><TD CLASS="quote">
IT SURE IS!!!!</TD></TR></TABLE>
lol i noticed that also haha..i wasnt going to say anything cause i figured someone else would..and sure enough..
hary6
Dec 14, 2009 08:07 PM
Blah.
Oct 6, 2008 10:41 PM
rcoolb2002
Apr 18, 2006 10:32 PM
FalconMan
May 8, 2003 03:51 PM
