??? vtec problem ???
Old Dec 25, 2007 | 06:08 PM
em1mata's Avatar
Default ??? vtec problem ???
ok so I have a 93 D16 and my vtec no longer quicks in, everyhting was fine but now it doesn't want to work. No check engine light goes on, recently, I changed the oil, could it be that it's over fueled or what? How can I go by checking if the vtec is working or what the problem is? Thanks!
Old Dec 25, 2007 | 07:37 PM
Cln94EG1's Avatar
Default Re: ??? vtec problem ??? (em1mata)
Grab a Wire and 12V source then hit the top of the Vtec Head and Listen for a Click
Old Dec 25, 2007 | 07:40 PM
92sihbk's Avatar
Default Re: ??? vtec problem ??? (cln92eg)
what makes you think it doesnt work?
Old Dec 25, 2007 | 09:39 PM
em1mata's Avatar
SAY i HEAR A CLICK, WHAT HAPPENS NEXT? THANKS!
Old Dec 25, 2007 | 09:40 PM
Cln94EG1's Avatar
If u hear it Click then its working but if its not working while driving then theres other problems
Old Dec 25, 2007 | 09:41 PM
blueEM1's Avatar
check your oil level, my car had the same sort of issue, i was almost due for an oil changin then my vtec would iintermitenly work, checked the oil level and it was low, added oil and worked perfectly fine
Old Dec 25, 2007 | 09:46 PM
em1mata's Avatar
u think maybe it has a lot of oil cuse some guy told me that if it has a lot of oil the vtec won't function properly and I need to take some oil off, that single cam only takes in 3 1/2 quarters and I put in 4. U think it might b that?
Old Dec 25, 2007 | 09:49 PM
Cln94EG1's Avatar
Shouldnt be is your MPH's working
Old Dec 28, 2007 | 10:36 AM
DougNuts's Avatar
Where do I stick the 12v wire again? My vtec is also not working, at all. I have no CEL or anything. It apparently hasn't worked since I put in the motor. I've tried a new solenoid, didn't do anything.
Old Dec 28, 2007 | 10:38 AM
Cln94EG1's Avatar
Default Re: ??? vtec problem ??? (DougNuts)
The 12V wire goes to the top of the Vtec solenoid
Old Dec 28, 2007 | 10:57 AM
DougNuts's Avatar
Does the car need to be running?
Old Dec 28, 2007 | 10:59 AM
Cln94EG1's Avatar
No I did my check with it off the car so im sure u dont have to have the car running
Old Dec 28, 2007 | 11:13 AM
DougNuts's Avatar
Ok, I'm an idiot. Where do I get the 12V power from and where exactly do I touch the wire to on the solenoid?
Old Dec 28, 2007 | 11:23 AM
Cln94EG1's Avatar
12V Source This is what I used
And Heres My Sweet Draw up lol
Old Dec 28, 2007 | 11:26 AM
NOFX's Avatar
H-T White Ops
What makes the OP think his VTEC isn't working?
Old Dec 28, 2007 | 11:30 AM
Cln94EG1's Avatar
Default Re: (NOFX)
Dont Know
DougNuts's Avatar
When I did the battery to top of solenoid, it sparked like a MFer. I didn't really take the time to listen for a click, but I did hear a nice electrical pop.
Old Dec 28, 2007 | 11:33 AM
Cln94EG1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DougNuts &raquo;</TD></TR><TR><TD CLASS="quote">When I did the battery to top of solenoid, it sparked like a MFer. I didn't really take the time to listen for a click, but I did hear a nice electrical pop.
HAHAHA wear Gloves and Im sry u have to ground it also
Old Dec 28, 2007 | 11:52 AM
DougNuts's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cln92eg &raquo;</TD></TR><TR><TD CLASS="quote">
HAHAHA wear Gloves and Im sry u have to ground it also </TD></TR></TABLE>
Even with it grounded, I just manage to do a bunch of arc welding.
Old Dec 28, 2007 | 11:59 AM
Syndacate's Avatar
Even with it grounded, I just manage to do a bunch of arc welding. </TD></TR></TABLE>
That's because you just connected a positive terminal to an open ground (the VTEC solenoid). It's no different from sticking a ratchet in between your battery terminals.
I don't know the proper decor for where you're supposed to connect the power wire, but touching it to an open metal body like that will give you the infinite ampere dilemma (I don't know if you've ever taken any computer science courses but if you did you'd know what that is) which is why it looks like somebody took a torch to your solenoid.
Old Dec 28, 2007 | 12:02 PM
DougNuts's Avatar
Default Re: ??? vtec problem ??? (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
That's because you just connected a positive terminal to an open ground (the VTEC solenoid). It's no different from sticking a ratchet in between your battery terminals.</TD></TR></TABLE>
EDIT: The solenoid is working correctly when a 12 volt is applied. You have to apply the power to the plug, not just touch the solenoid.
Modified by DougNuts at 4:59 PM 12/28/2007
Old Dec 28, 2007 | 03:28 PM
DougNuts's Avatar
Ok, next step is to install a vtec light so I know if the ECU is sending power to the solenoid.
Now, my question is, is there a way to electronically turn on vtec all the time? If I could make vtec engage, then I can rule out a mechanical failure.
If the car is idling and I supply 12v to the solenoid, will the vtec engage or will there not be enough oil pressure?
Old Dec 28, 2007 | 03:35 PM
wicked_b16eg's Avatar
Default Re: (DougNuts)
there are parts on the car that control this function, oil a signal to it from the ecu and a knock sensor. also it could be that it is working and you just not hearing it. hook a wire from selinode ( the one wire not the two coming from the pressure switch) to a light in you car then ground the other terminal of the light. Now Go out and see if it turns on or not. If it does then you have vtec.
Old Dec 28, 2007 | 03:49 PM
DougNuts's Avatar
Default Re: (wicked_b16eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wicked_b16eg &raquo;</TD></TR><TR><TD CLASS="quote"> also it could be that it is working and you just not hearing it. </TD></TR></TABLE>
I could care less about hearing it. My dyno graph that peaked at 5050rpm and took a nose dive tells me that vtec isn't engaging.
Old Dec 28, 2007 | 04:01 PM
but wiring some where, bad grounds? ECU? knock sensor, cam sensor, bad vtec selinode, oil pressure?
