want to run old B18(non-Vtec) all motor on pump gas
Old Dec 25, 2007 | 06:04 PM
Ole' B18's Avatar
Default want to run old B18(non-Vtec) all motor on pump gas
I have a 1993 teg gs w/ 5spd. and a hks 3'' hi-power catback and thats it. I would like to add aggressive cams and hedders hi flow cat etc... I can port and relive the head myself . any help!?
Old Dec 26, 2007 | 08:56 AM
gibsanez's Avatar
Default Re: want to run old B18(non-Vtec) all motor on pump gas (Ole' B18)
How many B18's do you have if you're running "hedders"?
Old Dec 26, 2007 | 09:31 AM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ole’ B18 &raquo;</TD></TR><TR><TD CLASS="quote"> I can port and relive the head myself . any help!? </TD></TR></TABLE>
Do you know how to port or what happens if you do it wrong?
From the sounds of it, you need to do a lot more reading before you start doing. When a baby comes into the world, everything is new to them and they don't become experts overnight. They have to crawl before they walk and walk before they run and it all takes time. Put in the time you need to learn to do it right and then start doing it.
Old Dec 27, 2007 | 04:40 AM
Ole' B18's Avatar
Default Re: want to run old B18(non-Vtec) all motor on pump gas (00Red_SiR)
yes i know how to port and the head will crack if i do it wrong.... my grandfather was an stockcar driver and he built his own motor im not coming in to this blind. he showed me how & said if i need help to ask him just cause im new doesn't mean im stupid! oh and hedders was a spelling error.
Old Dec 27, 2007 | 06:55 AM
penaj778's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ole’ B18 &raquo;</TD></TR><TR><TD CLASS="quote">yes i know how to port and the head will crack if i do it wrong.... my grandfather was an stockcar driver and he built his own motor im not coming in to this blind. he showed me how & said if i need help to ask him just cause im new doesn't mean im stupid! oh and hedders was a spelling error.
I think there are a lot more things that would go wrong way before the head "cracks". porting a head is an art form. just because you have a die grinder and someone who used to build engines decades ago doenst mean you can port a head and you will gain horsepower. head design from a honda engine from the 90's is completely different than a chevy 350 (or what ever other american manufacture) from the 60's. the same porting ideas and practices on a 350 head in the 60's will most likely ruin a good honda head.
Modified by penaj778 at 8:07 AM 12/27/2007
Old Dec 27, 2007 | 07:02 AM
The Taxi Driver's Avatar
* B A N N E D *
Holy ****, youre my favorite honda-tech member ever. and tell your grand-pappy i said hello.
Old Dec 27, 2007 | 03:13 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: want to run old B18(non-Vtec) all motor on pump gas (penaj778)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by penaj778 &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by penaj778 at 8:07 AM 12/27/2007</TD></TR></TABLE>
x2
Porting a head incorrectly will lose power to begin with and if you really screw it up you might grind into a coolant passage, causing cracking etc. Like you said, you're familiar with motors because your grandfather use to race stock cars and build engines and therefore all his knowledge transfered genetically down the line into you when you were born. Look, my grandfather was a hell of a mechanic but I still learned everything I know, mostly on my own. At most I gained an aptitude for mechanics from him but I still had to put in the time and effort. It's clear to anyone that has a reasonable amout of mechanical knowledge here, that at best, you're at the early stages of knowledge. There's nothing wrong with that, every one of us started there....where you go from there is up to you. People will help you here if you show a willingness to do some searching and learning on your own before you post questions.
Old Dec 29, 2007 | 06:31 AM
Ole' B18's Avatar
your right i guess i have to learn alot more before i start opening up the head. the motor my grandfather was running was a twin cam 4cyl pontiac
hondafan16
Mar 14, 2012 10:10 PM
matzekm
May 18, 2009 05:02 PM
Tornadom
12
Jan 2, 2006 06:25 PM
NITROUSHONDA
Jun 23, 2005 03:41 PM
