wiring harness for hids in a honda civic up to 2000
alot of people have asking for this latley so her you go
this one is for low beam only
please bump if it helps you out thanks
Modified by turbo-2nr at 5:45 PM 12/27/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo-2nr »</TD></TR><TR><TD CLASS="quote">
this one is for bi-Xenon(low/high)
That is for ground switched H4 harness....Not for 2000 Civic because it is positive switched....for civics 2001-2005 that is right harness...that's what I used
Good effort
http://www.hidplanet.com/forum...27743
Good effort
it depends on the ballast...
if the ballast's max draw is 15 amps, then 1 30 amp relay is fine... get a relay that can handle the total amount of amps that both ballast draw...
also, if you have a h4 bulb..
you might want to do this instead:
these diagrams aren't the best... and are sort of confusing... but if you can follow the colors and the line widths... i guess it works... sorta.. https://honda-tech.com/zerothread/1871411
EjSex
Audio / Security / Video
Jan 4, 2008 10:05 AM
