hondata 300 j questions
Old Dec 25, 2007 | 04:13 PM
casseltech's Avatar
Default hondata 300 j questions
hey guys i have a new crx si with a GSR swap tuned with the s300 J system and the original tune was done a different computer. I now have a different computer which i have already downloaded the s300 manager on, cause I dont have the disk. I plug the usb cable in and all i can do is data logging though, I cant change launch control, rev limit, full throttle shifting or any of the parameters. can i open a new calibration and load parameters or will that erase the tune thats on the ecu?Do I need to have the the old computer with the tune saved to it to open it up and do anything? if so how can i do this or do i need that disk or the old computer or is there something im doing wrong? any help would be great thanks.
oh and question on cooling every time i go for a pull and hit the gas the engine temp gets colder on the data logging and the gauge drops to cold then i lose vtec im pretty sure the vtec is linked to the gauge on the cluster but the gauge is reading competely cold but hondata says its a 145 to 150 what temp does vtec kick in at? any ideas?
Old Dec 26, 2007 | 12:46 AM
mtber's Avatar
Default Re: hondata 300 j questions (casseltech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by casseltech &raquo;</TD></TR><TR><TD CLASS="quote">hey guys i have a new crx si with a GSR swap tuned with the s300 J system and the original tune was done a different computer. I now have a different computer which i have already downloaded the s300 manager on, cause I dont have the disk. I plug the usb cable in and all i can do is data logging though, I cant change launch control, rev limit, full throttle shifting or any of the parameters. can i open a new calibration and load parameters or will that erase the tune thats on the ecu?Do I need to have the the old computer with the tune saved to it to open it up and do anything? if so how can i do this or do i need that disk or the old computer or is there something im doing wrong? any help would be great thanks.
oh and question on cooling every time i go for a pull and hit the gas the engine temp gets colder on the data logging and the gauge drops to cold then i lose vtec im pretty sure the vtec is linked to the gauge on the cluster but the gauge is reading competely cold but hondata says its a 145 to 150 what temp does vtec kick in at? any ideas?</TD></TR></TABLE>
Downloading data from the s300 unit is generally not a good idea as the parameters are not always 100% accurate compared to the original calibration.
Go to hondata.com and download the smanager if you have not.
Update it & follow the help file instructions on connecting to your ecu.
2001GSRSC
Jan 30, 2018 12:10 PM
949
Engine Management and Tuning
34
Feb 20, 2015 06:15 PM
jrock1234
Feb 26, 2012 06:19 AM
dev203d
Jun 15, 2009 10:23 AM
speeddave
Dec 17, 2007 12:17 PM
