Integra LS grinding and i don't think its the tranny.
Old Dec 25, 2007 | 12:58 PM
Yaa's Avatar
Yaa
Default Integra LS grinding and i don't think its the tranny.
Well about 5 months ago my car suddenly started to make a grinding sound coming from the engine bay, it grinds in in every gear including reverse, when have the pedal pressed it does not make a sound but when it engages it makes this grinding that sounds like to metal gears grinding together. It might be the tranny but im unsure.
Im sorry if this isnt descriptive enough, ask me a question about it and i will awnser.
Thanks in advance.
Old Dec 25, 2007 | 01:54 PM
weavertime1's Avatar
Default Re: Integra LS grinding and i don't think its the tranny. (Yaa)
Input shaft bearing on the tranny or throw out bearing...just a shot in the dark. Good luck
Old Dec 25, 2007 | 01:56 PM
db1_jdm's Avatar
hows the fluid?
Old Dec 25, 2007 | 02:11 PM
Yaa's Avatar
Yaa
Default Re: Integra LS grinding and i don't think its the tranny. (db1_jdm)
fluid is good, i got that changed as soon as the grinds started.
Old Dec 26, 2007 | 08:33 AM
Yaa's Avatar
Yaa
T T T
Old Dec 26, 2007 | 08:44 AM
tsdneil's Avatar
a guy on her not too long ago actually had a piece of his pressure plate lodged between the flywheel and clutch. i mean thats probably not your problem, but theres always the chance.
Old Dec 27, 2007 | 01:22 PM
Yaa's Avatar
Yaa
Default Re: (tsdneil)
TTT
Old Dec 27, 2007 | 01:34 PM
hatchling37's Avatar
Default Re: (Yaa)
Input shaft bearing. Here's the link for an awesome rebuild.
Tranny rebuild
I think it tells you how to go about replacing it. Not difficult, done it a couple of times. Just buy a whole bearing kit to replace all of them while you're in there. Save you some headaches.
Old Dec 27, 2007 | 02:53 PM
Yaa's Avatar
Yaa
Default Re: (hatchling37)
from what ive read up on input shaft bearings it makes a "whine at high RPM, and a chatter/clicking from the transmission at idle." i don't get a high rpm whine or chattering/clicking, what i get sounds like two metal gears rubbing together with no lube.
Old Dec 29, 2007 | 06:13 AM
Default Re: (Yaa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yaa &raquo;</TD></TR><TR><TD CLASS="quote">from what ive read up on input shaft bearings it makes a "whine at high RPM, and a chatter/clicking from the transmission at idle." i don't get a high rpm whine or chattering/clicking, what i get sounds like two metal gears rubbing together with no lube. </TD></TR></TABLE>
OK...if the car does not make the sound when the clutch is in, it has to be a transmission problem. Letting the clutch out connects the engine and the transmission to "turn" as one. Even if you are in neutral, and the clutch is out, things are moving in the tranny. So from your description, I would have to say that your issue is in the transmission, and my first guess would an input shaft or throwout bearing issue as I stated before. Good luck!
Modified by weavertime1 at 10:44 AM 1/3/2008
nanagsr
Mar 30, 2009 10:26 AM
Cln94EG1
12
Dec 19, 2007 02:16 PM
hmtcrxsir
Nov 7, 2007 05:07 AM
4drferio
Apr 29, 2004 10:59 AM
ahc'monracing
20
Mar 4, 2003 06:44 PM
