DET scanners. Who uses them? How did you make it?
Old Dec 25, 2007 | 10:40 AM
98vtec's Avatar
moderator emeritus
Default DET scanners. Who uses them? How did you make it?
i bought a stethescope from harbor freight and i'm looking to convert it to be used in detection of knock. Plans are to put a big magnet on the end of the scope so it is securely attached to the block then run long tubing through the firewall which are going to be attached to either the ear piece that came with the scope or to a set of ear protectors (for lack of a better term).
anyone else use these to tune and dont mind sharing how you made it?
Old Dec 25, 2007 | 11:17 AM
MAX_CFM's Avatar
Default Re: DET scanners. Who uses them? How did you make it? (98vtec)
use this .. works alot better
Old Dec 25, 2007 | 11:19 AM
Combustion Contraption's Avatar
What about this?
Old Dec 25, 2007 | 11:30 AM
98vtec's Avatar
moderator emeritus
Default Re: (Combustion Contraption)
how is a band saw going to help?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAX_CFM &raquo;</TD></TR><TR><TD CLASS="quote">use this .. works alot better
I'm sorry but i dont quite understand the use of that by looking at a picture and i cant find it on their website.
the point of doing it the way i described is because of the price.
Old Dec 25, 2007 | 11:31 AM
Looks like a real nice spark plug inspection tool. Plugs will 'pick up' traces of knock that a knock sensor wont.
Old Dec 25, 2007 | 11:34 AM
98vtec's Avatar
moderator emeritus
yes, but im not going to pull the plugs while i am tuning the ignition in real-time. Too time consuming. Especially when all i am trying to accomplish is basically getting a hearing aid for the combustion chamber.
Old Dec 25, 2007 | 11:51 AM
Ok, im all out of jokes. I dont have much experience when it comes to knock detection instruments.
Old Dec 25, 2007 | 12:43 PM
98vtec's Avatar
moderator emeritus
anyone else?
Old Dec 25, 2007 | 08:23 PM
.dave's Avatar
i HAS questions ?
Default Re: (98vtec)
I built a set using a piece of copper tubing hammered flat at one end and hooked up to hard plastic tubing that ran to a pair of old shooting ear muffs.
In my opinion its easier to just tune on a dyno than trying to speculate about what you may or may not have heard.
Old Dec 25, 2007 | 11:33 PM
mtber's Avatar
Do a search you newb
hondacrx2
Paint and Body
23
Jan 3, 2008 06:52 AM
BJA86
Audio / Security / Video
23
Nov 11, 2007 04:01 PM
PrettyFastRide
18
Aug 26, 2006 10:50 PM
Evile140
Welding / Fabrication
Dec 27, 2005 01:01 PM
