Help with SRS light and check engine
My 95 honda civic SRS light in dashboard is flashing on and off, and after that my check engine light starts flashing 9 times and then stops and continues like that, im scared of what could it be?
in the CEL thread it says to have the car off and also to cover the 2 pin plug with a connector i didnt do that, my car was on and it suddently started doing and now it does it all the time. BTW going by the thread then it would be code #9 which is cylinder sensor
Are you sure you counted them right, b/c of the long + short blinks? If so, im not familiar with the cylinder sensor. Try using the search button and searching it, and im sure others chime in and help you out.
G. Man
12
Feb 25, 2011 06:13 PM
boosted96midorihatch
May 14, 2006 09:03 AM
