Christmas day problem......
Old Dec 25, 2007 | 08:31 AM
Tip14's Avatar
Default Christmas day problem......
The car is a 1992 Accord Lx. For Christmas my brother got a new battery for his car because the old one was bad. Well today we put it in and the car wont turn over or anything it has no electrical power what so ever. The lights dont turn on nothing. We tried jumping it thinking the battery had no charge still nothing. Anybody have any ideas? I searched and think it may be the main realay but it wont turn over or anything so Im a little confused.
Old Dec 25, 2007 | 08:47 AM
Sean Juan's Avatar
Default Re: Christmas day problem...... (Tip14)
Check the ground?
Old Dec 25, 2007 | 08:49 AM
Tip14's Avatar
The ground is good. Whats next?
Old Dec 25, 2007 | 09:22 AM
sony224422's Avatar
Default Re: (Tip14)
make sure its getting a good connection.. try the battery out of your car to see if its the battery.. check the battery fuse
Old Dec 25, 2007 | 09:56 AM
The-Kid's Avatar
Default Re: (sony224422)
Ditto on the battery fuse.
Old Dec 25, 2007 | 11:08 AM
91ex's Avatar
Default Re: (The-Kid)
the battery must be bad or you have a bad connection. check all the under hood fuses but it should be that main black fuse coming in. is your positive cable terminated correctly going in to the fuse box?
Old Dec 25, 2007 | 06:35 PM
Tip14's Avatar
Where is the battery fuse? Anybody have any pics. Also the battery is good tested it on my prelude and it fired right up.
Old Dec 25, 2007 | 06:56 PM
sony224422's Avatar
Default Re: (Tip14)
battery fuse is in the underhood fuse box. its a big *** fuse, i think its like 80 amps... hard to miss. its got a clear plate over it with two bronze things coming off each side, thats how its mounted. it should be in the middlish i think.
Old Dec 26, 2007 | 04:44 AM
Tip14's Avatar
Alright well I willl check it after work today. I will get back to ya'll. Thanks for your help so far
Old Dec 26, 2007 | 09:56 PM
next_evolution's Avatar
Default Re: (Tip14)
has anyone started with the basics first? like checking the "new" battery for juice? or how about using a D.V.O.M.(digital volt ohms meter) to check for at least a 12.4 volt charge? cause even new parts go bad. and even if it does have a 12.4 volt charge id put it in and check the charge through the cables and see what voltage you(thus ruling out and fuses being bad) then id start the car with the meter in place to see where the voltage went (like if it drops to .02 volts when you hit the key) so id definitely check the basics first before heading into bigger diagnostics
Old Dec 26, 2007 | 10:02 PM
sony224422's Avatar
Default Re: (next_evolution)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by next_evolution &raquo;</TD></TR><TR><TD CLASS="quote">has anyone started with the basics first? like checking the "new" battery for juice? or how about using a D.V.O.M.(digital volt ohms meter) to check for at least a 12.4 volt charge? cause even new parts go bad. and even if it does have a 12.4 volt charge id put it in and check the charge through the cables and see what voltage you(thus ruling out and fuses being bad) then id start the car with the meter in place to see where the voltage went (like if it drops to .02 volts when you hit the key) so id definitely check the basics first before heading into bigger diagnostics </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tip14 &raquo;</TD></TR><TR><TD CLASS="quote">Where is the battery fuse? Anybody have any pics. Also the battery is good tested it on my prelude and it fired right up.</TD></TR></TABLE>
hmm read much? not to say that means the battery is 100%, but its not the battery, not to mention even a dead battery will turn on the cluster lights for a second or two.
Old Dec 27, 2007 | 01:13 PM
Tip14's Avatar
The battery Fuse is what was wrong with it! Im going to autozone tonight to get one. Thanks for ya'lls help!!!
seamus657
Mar 6, 2009 08:47 PM
Ruben19
Oct 10, 2007 08:49 AM
rhd_ef8
12
Apr 29, 2007 11:27 AM
metalgears
Feb 18, 2006 01:43 PM
DiSbaDbOi
16
Jan 5, 2005 07:24 PM
