IACV issues... cleaned it, replaced it, and searched forums... please help
okay so ive cleaned my IACV a few times... reset the ecu each time, and still have issues with it... i can drive it some days with no problems, and other days it acts up... the idle will jump back and forth very fast from about 1200rpms to 1300rpms... and when i start to drive, the engine behaves violently... from a stop it takes alot of gas to get going and between each shift the rpms go down instantly causing a very rough transition... ive replaced the IACV with another working used one straight off of my friends car and it still has issues... could it be the plug itself?
fyi its an 01GSR obd2
may have a air leak (test with carb cleaner) , or a crazy *** air bubble in your water system.
condition of spark plugs/cap/wire...
valves...
if you did anything to the car as in MSD and such..replace with stock to see how it works out.
Good Luck
valves...
Good Luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvilPinkEye »</TD></TR><TR><TD CLASS="quote">may have a air leak (test with carb cleaner) , or a crazy *** air bubble in your water system.
valves...
Good Luck</TD></TR></TABLE>
yea try that first....if not try cleaning out your Fast idle thermo valve..g/l
valves...
valves...
hmmm... i just replaced the cap/rotor/wires/and spark plugs last month... i bled the cooling system 2 weeks ago thinkong that was the problem... but it runs fine until all of a sudden it starts acting up sometimes... its really wierd... has no ignition upgrades cuz stock is fine for me... and i adjust the valves every 15k which i just did about 7k ago and it didnt fix it... hmmm... well thx for your help... i appreciate the suggestions
valves...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fern413 »</TD></TR><TR><TD CLASS="quote">yea try that first....if not try cleaning out your Fast idle thermo valve..g/l
nah the car dont have an FITV... its OBD2... your on track tho thx... if i had one id clean it haha...
</TD></TR></TABLE>nah the car dont have an FITV... its OBD2... your on track tho thx... if i had one id clean it haha...
BTW... it throws a CEL 14 which is IACV problem but just can't figure it out...
haha
haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rikter »</TD></TR><TR><TD CLASS="quote">take it to a dealership.l
-Rik</TD></TR></TABLE>
haha ya right
haha ya right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91Civic300K »</TD></TR><TR><TD CLASS="quote">Check your PCV for a leak.</TD></TR></TABLE>
hmm... ill check that when i get a chance to...
