can someone verify this for me its about extension cords
Old Dec 24, 2007 | 07:28 PM
stockmr2's Avatar
Default can someone verify this for me its about extension cords
just got a welder but need a extension cord from my dryer to garage.
on another forum, a guy was sayin that i can buy a standard 110v heavy duty 10/3 extension cord and change the receptacle.
i looked up a 110v 10/3 heavy duty cord at my local store and its is rated at 20amp.
my question is :
are all 10/3 wires strand and solid the same?
the ext. cord that i looked up that is rated at 20amp, is that the receptacle or the wire that is 20amp limited
Old Dec 24, 2007 | 07:50 PM
Syner-G-Racing LLC's Avatar
Default Re: can someone verify this for me its about extension cords (stockmr2)
get something around 50amps rated. it'll be good for 40 amps continuous. if you weld long runs or anything pulsed on that 20amp your gonna trip the breaker or the extension cord will get pretty close to melting. I use 8/3 ext cables for 50' or less and if its gonna be 75' bigger I use 6/3. just search "welder extension cords" in google. they'll show where to get em. I get 50' for for $65-$75.
Old Dec 24, 2007 | 08:03 PM
k24em2's Avatar
What kind of welder did you buy?
Old Dec 24, 2007 | 08:04 PM
RCautoworks's Avatar
I used two of these on this site, was cleared by the inspector. Went this route for some time, then changed. I never noticed a voltage drop until I welded with out these. I use to set my amps to like 70 and weld sch10, now I can set it to about 50 and weld sch10
http://www.brwelder.com/indext...y=155
Old Dec 24, 2007 | 08:21 PM
essex's Avatar
Default Re: can someone verify this for me its about extension cords (RCautoworks)
I used this with the dryer plug
http://store.weldingdepot.com/....html
I bought it from Home depot though....it's stranded
Old Dec 24, 2007 | 11:30 PM
stockmr2's Avatar
Default Re: can someone verify this for me its about extension cords (essex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by essex &raquo;</TD></TR><TR><TD CLASS="quote">I used this with the dryer plug
I bought it from Home depot though....it's stranded</TD></TR></TABLE>
i went to my local hd and lowes but they didnt have any stranded 10/3s. thats what i was looking for and but in 30amp, i was trying buy it locally but couldnt find it. hence the orignal question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">What kind of welder did you buy?</TD></TR></TABLE>
clarke 180en 220v mig single phase.
i know its not great but also didnt want to go broke on my first welder.
Modified by stockmr2 at 12:41 AM 12/25/2007
Modified by stockmr2 at 12:42 AM 12/25/2007
Old Dec 25, 2007 | 12:04 AM
stockmr2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syner-G-Racing LLC &raquo;</TD></TR><TR><TD CLASS="quote">get something around 50amps rated. it'll be good for 40 amps continuous. if you weld long runs or anything pulsed on that 20amp your gonna trip the breaker or the extension cord will get pretty close to melting. I use 8/3 ext cables for 50' or less and if its gonna be 75' bigger I use 6/3. just search "welder extension cords" in google. they'll show where to get em. I get 50' for for $65-$75. </TD></TR></TABLE>
im almost sure my welder is 30amp max and my dryer breaker is 30 or 40 amp and the length im trying to obtain is 40-50 ft
Old Dec 25, 2007 | 12:09 AM
k24em2's Avatar
i wouldnt run anything smaller than stranded 8/3
Old Dec 25, 2007 | 12:29 AM
stockmr2's Avatar
Default Re: can someone verify this for me its about extension cords (k24em2)
aite ill go wid 8/3 but i couldnt find it for the price you guys saying your finding it for (65-75). $127 is the lowest i found is that normal pricing?
Old Dec 25, 2007 | 12:32 AM
k24em2's Avatar
Copper is high right now, so yes. You could probably save some money if you make your own cable.
ehhhdc2
Sep 25, 2007 10:33 AM
Diyracing2
Welding / Fabrication
Jan 24, 2007 03:57 PM
*Boostwerks*
13
Feb 7, 2006 11:27 AM
RACEPAK
Sep 28, 2005 08:53 AM
Mike D
47
Aug 20, 2004 05:43 AM
