Anybody running P73 pistons and cams in a C1?
Old Jun 28, 2002 | 08:35 AM
VTC_CiViC's Avatar
Default Anybody running P73 pistons and cams in a C1?
I'm just curious as to what kind of gain i'm looking at by going with a set of USDM ITR pistons and CTR/ITR cams, is it a worthy upgrade? Say $2-300 for the pistons and $500 for the cams?
Old Jun 28, 2002 | 08:38 AM
Chubz's Avatar
Default Re: Anybody running P73 pistons and cams in a C1? (VTC_CiViC)
Your compression should be around 10:8:1 or 10:9:1. A more worthy investment would be JDM ITR pistons, you will be around 11:5:1. Or ctr pistons which is 12:3:1 in a GSR engine (you can use pump gas, im running 12:1 timing is at 16 BTDC, fuel pressure at 50 psi with the vacum line on (also running JUN III)
[Modified by SuperTech, 5:39 PM 6/28/2002]
Old Jun 28, 2002 | 08:52 AM
stick's Avatar
i hope these are for ur GSR.
make sure u have a decent header w/ good flow ie JDM 4-1 or any header w/ 2.5 collector, vtec controller to take care of the cams duration, cam gears to adjust,
decent exhaust like 2.5 in mandrel bent and tuning, tuning, tuning.....
Old Jun 28, 2002 | 09:23 AM
VTC_CiViC's Avatar
Default Re: Anybody running P73 pistons and cams in a C1? (stick)
What did you think they were for?
Old Jun 28, 2002 | 09:33 AM
stick's Avatar
i saw the first car in ur sig and i was thinking hybrid on me
CaliKing
Aug 31, 2011 06:31 AM
iwantahatch
Nov 13, 2008 08:39 PM
Twisted driver
Jan 26, 2006 07:04 AM
ysrhatch
Aug 24, 2001 06:28 PM
Acura97GSR
Jul 3, 2001 03:00 PM
