The last A/C Question
I know this question has been asked a million times, and after all my searching none have given a defente answer.
I have a JDM B18C, have my D16 compressor, so I need the bracket and tensioner form the Del Sol VTEC right?
well thats the problem, its a GSR from Japan not a B18C1 like here, and you cant because it will not bolt to the d series compressor, and if you use a B series compressor you have to change the line adapters that screw onto the compressor
cant you use a b series compressor and just use the b series lines? Seems like its going to be really difficult to find/buy the brackets to get a d-series compressor to sit flush.
B-series swap into a 92-00 civic and would like to use the d-series compressor either uses the delsol vtec a/c bracket (P54) or the cheaper USDM crv (b20b 96+). I ordered mine from honda for a 98 CRV. I used my stock d-series compressor. The USDM b20 CRV uses the identical a/c compressor.
Part Number:
Part Number:
^ thanks you are awesome, and i also need the tensioner and all the bolts to for it right?
Modified by 95jdmcivic at 3:57 PM 12/24/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deckster333 »</TD></TR><TR><TD CLASS="quote">cant you use a b series compressor and just use the b series lines? Seems like its going to be really difficult to find/buy the brackets to get a d-series compressor to sit flush.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95jdmcivic »</TD></TR><TR><TD CLASS="quote">well thats the problem, its a GSR from Japan not a B18C1 like here, and you cant because it will not bolt to the d series compressor, and if you use a B series compressor you have to change the line adapters that screw onto the compressor</TD></TR></TABLE>
why are you paying attention to this guy? obviously he doesn't know what he is talking about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slothy »</TD></TR><TR><TD CLASS="quote">B-series swap into a 92-00 civic and would like to use the d-series compressor either uses the delsol vtec a/c bracket (P54) or the cheaper USDM crv (b20b 96+). I ordered mine from honda for a 98 CRV. I used my stock d-series compressor. The USDM b20 CRV uses the identical a/c compressor.
Slothy is right, usinf the P7J bracket is cheaper and is identical to the P54. why honda has them listed at a different price who knows.
as for the belt, you want to use the compressoer belt for the d-series compressor. the b-series compressor is alittle bigger and wont fit.
Slothy is right, usinf the P7J bracket is cheaper and is identical to the P54. why honda has them listed at a different price who knows.as for the belt, you want to use the compressoer belt for the d-series compressor. the b-series compressor is alittle bigger and wont fit.
Wow I'll have to keep this in mind..good info!!!
I had a real hard time finding b16 brackets and a b16 ps pump for my swap so I thought the AC might be specific as well. I did not install the AC.
gato5254
10
Dec 1, 2013 07:47 PM
genevievesalad
May 17, 2012 03:14 PM
slowpokesi
17
Jul 20, 2002 08:31 AM
