Low/no power steering assist
I recently did a timing belt and waterpump on the integra.
Saw that the power steering belt was cracking. Went ahead and
got a new belt at kragen. But now the belt squeek and has a burning smell.
Like a rubber burning. At cold start there is no power steering and belt
squeek.
At first I thought the belt was too loose so I went ahead and double checked today.
Power steering fluid is fine. There is no leak on the rack.
Squeek. Rubber burning smell. Little power steering when at u-turns/cold start.
squeek.
The squeek sound is the belt slipping. Due to not being tight enough or just a little wet. When it is slipping its not pumping fluid, there for you dont have power steering.
So check to make sure it is the correct belt, or tighten it up,
EK k kay
Dec 28, 2004 02:49 PM
