Lighting HID/Xenon kits, Retrofits and Associated Topics
2000 civic projection question!!! HID
Old Dec 23, 2007 | 07:33 PM
Import_2's Avatar
Default 2000 civic projection question!!! HID
quick question, i replaced my headlamps with TYC projection lights, there awsome just want to know if i put HID bulbs in them will it melt anything due to heat? or should i be fine? there H1 type and i can get a set for a half decent price...quick answers would be awsome!
these are my headlamps, and im using normal silverstar h1 bulbs if i used a 10 000K HID think it would help?
Old Dec 23, 2007 | 07:58 PM
prelude1897's Avatar
Default Re: 2000 civic projection question!!! HID (Import_2)
if you're planning on putting HIDs in these projector headlights, I wouldn't go any higher than 6000k bulbs. Same thing if you have an actual retrofit
Old Dec 23, 2007 | 08:48 PM
siqueen23's Avatar
Default Re: 2000 civic projection question!!! HID (prelude1897)
i put 8000k in my projector headlights i had on my ex.. they didnt melt anything they shuld work fine.. mine took h3 hid 8000k..
Old Dec 23, 2007 | 08:52 PM
siqueen23's Avatar
Default Re: 2000 civic projection question!!! HID (siqueen23)
also i wouldnt go any higher than 8000k because then your gettin more blue and then you can't c as well there not as bright..
these are 8000k and there so bright...
Old Dec 23, 2007 | 10:15 PM
Tru2Less's Avatar
hid is actually alot cooler than the factory light bulb itself
Old Dec 23, 2007 | 10:42 PM
Ruben19's Avatar
hids are 35w compare 55w to halogen bulbs
dont let brighter fool you
Old Dec 26, 2007 | 11:32 AM
chawski's Avatar
the color temp of the lights has absolutely nothing to do with the actual temperature. H1 projectors already suck for halogen, and are gonna be even worse for hid. Youre gonna throw the focal point off and have horrible light spread. ive sen guys using those projectors with hid and the light was barely as wide as the car. these are, hoever a great housing to do a retrofit on. seriously, save youre money and do it right the first time
Old Dec 26, 2007 | 11:41 AM
gsr camel's Avatar
Default Re: (chawski)
with that said, I'd hate to see what something 8000 Kelvin would do to a car
Old Dec 27, 2007 | 08:40 AM
Genuine Rolla's Avatar
go with 4300K. Nothing will melt. HID's run cooler than Halogen.
Igaly
Honda Civic (2001 - 2005)
Feb 22, 2010 06:50 PM
robbys89
Feb 9, 2009 09:44 AM
Import_2
Dec 23, 2007 07:31 PM
viskii420
Lighting
25
Oct 31, 2007 04:21 PM
SRCIVIC05
Aug 10, 2006 06:26 PM
