where can i get a sharp/tight radius 2.5" 90deg bend?
hey guys
anyone know where i can get a a sharp/tight radius 2.5" 90deg bend? preferably in stainless steel.
just found out my down pipe is cracked. i have a a/c compatible manifold that is really tight/close to the compressor so space is a real issue.
the current pipe is just a standard 90deg 2.5" pipe that was sliced/cut to make fit and i can hardly thread the bolts in since it's so tight. i wanna try and do a nicer job this time around. there has to be a better way...
thanks
thanks
http://www.acestainless.com/in...d=514
Unfortunately the tight radius bends cost like 3x as much as the standard radius bends.
ouch......that is pretty expensive for such a small peice....
how about mild steel....that should be cheaper?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy »</TD></TR><TR><TD CLASS="quote">http://www.acestainless.com/in...d=514
dont use that. its piping; not tubing. if you notice the ID is way bigger than 2.5" tubing. not to mention a downpipe made out that will weigh 50lbs!
try these...
http://www.atpturbo.com/Mercha...e=STL
try these...
THEDirtyDseriesWOOT
Welding / Fabrication
14
Dec 11, 2007 07:50 AM
underpressure02
Apr 5, 2006 11:09 AM
