brake bleeders for wilwood rotors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Sol on Steroids »</TD></TR><TR><TD CLASS="quote">are they the same size as oem?</TD></TR></TABLE>
well you have both available measure and compare them. if we had specs or somehting to go by then maybe we could help ya some more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egSLEEPER »</TD></TR><TR><TD CLASS="quote">well you have both available measure and compare them. if we had specs or somehting to go by then maybe we could help ya some more. </TD></TR></TABLE>
part number 140-6310-d for the system
couldn't tell you what size is in now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cln92eg »</TD></TR><TR><TD CLASS="quote">if theres a little bleeder valve then open it up and pump away close it off and it should be good </TD></TR></TABLE>
one of the valve is clogged or blocked. so one of the piston may still have air
hondahp21
Dec 5, 2006 04:25 PM
