clutch chatter?
Old Jun 28, 2002 | 02:08 AM
LOwrestling2001's Avatar
Default clutch chatter?
i have an ACT HD SS clutch. i guess when the clutch is cold (not shifted at high Rpms and stuff)...and u launch the car do u ever get chatter? as if the dash comes at u? and i think when it warms up then it launches normal? what is definition of clutch chatter? thanx
Old Jun 28, 2002 | 02:32 AM
ragejed's Avatar
Default Re: clutch chatter? (LOwrestling2001)
ya, i had the same problem. same setup too. I got motor mount inserts to keep the engine from movin around, works well for me. and i stilll have that last insert to get in.
Old Jun 28, 2002 | 04:48 AM
IN VTEC's Avatar
No chatter, but sometimes it does stutter on me sometimes b/c I don't give it enough gas.
ACT HD-SS
Toda FW
Old Jun 28, 2002 | 09:22 AM
born2speed's Avatar
Default Re: clutch chatter? (IN VTEC)
IN VTEC, I noticed that we have the smae setup for clutch and flywheel. I was wondering if you have experienced any problems. About 5k miles ago I started hearing like a grinding noise coming from the tranny area, but when you put the clutch in it goes away. I have no problem shifting or anything. Just wondering if you were experiencing anything weird as well.
Old Jun 28, 2002 | 10:24 AM
Default Re: clutch chatter? (born2speed)
no i haven't ahd any of those problems, but once again, anyone knwo the definition of "clutch chatter?" i'm not 100% on that.
Old Jun 28, 2002 | 11:15 AM
ragejed's Avatar
http://www.advanceclutch.com
go to the FAQs
Old Jun 28, 2002 | 12:00 PM
boostin GSR's Avatar
yea, same with me, it stutters a big if i dont give it enough gas
Old Jun 28, 2002 | 12:30 PM
allenp's Avatar
Clutch chatter:
Subjectively, chatter is the feeling of a low-frequency fore/aft acceleration of the vehicle during a clutch engagement, particularly when launching the vehicle. The frequency is typically between 8-14 Hz.
The cause of chatter is the vibration of the vehicle's driveline, particularly the axles in a FWD vehicle. As you are engaging the clutch, slight variations in the clutch system can cause torque fluctuations to be transmitted through the driveline. If the frequency of these fluctuations is close to the natural frequency of the vehicle drivetrain, then noticeable chatter can occur.
Chatter is typically worsened by high clampload clutches over ceri-metallic puck clutch discs.
Old Jun 28, 2002 | 12:39 PM
IN VTEC's Avatar
Just so I get a clear picture of what's going on....
Is this at idle with the tranny in neutral & clutch engaged (pedal up), or while moving with the car in gear?
Is it a constant grinding sound (like two metallics scraping against each other), or does it have a fluttering quality to it (like the intensity goes up and down)?
I'd put the problem somewhere between the clutch release bearing or the clutch hub. Clutch hub could have a loose spring or something falling off of it, causing it to scrape the face of the pressure plate or the flywheel.
Old Jun 28, 2002 | 12:46 PM
bamaTeg's Avatar
New User
sounds like the throw out bearing...your hear a rattling sound at idle in neutral then pressing clutch pedal it will disappear. Is that what it is doing?
Old Jun 28, 2002 | 01:22 PM
kendo's Avatar
New User
Default Re: clutch chatter? (allenp)
Your description of clutch chatter resembles similar problems in some helicopters known as critical dynamic tailboom modes. A low intensity vibration that is amplified when coinciding with the vehicles natural frequency. I hate small stupid problems that snowball like this one and annoy while driving.
Old Jun 28, 2002 | 06:29 PM
mike@coximport.com's Avatar
Default Re: clutch chatter? (kendo)
If you have a street disc, or an ACT SS disc, there should be NO chatter. If there is, it is due to a defective unit, which is not uncommon with ACT, or an installation problem. This has become status quo with many of the rebuilds. ACT, CM, CF, ect. Chatter is generally accepted with a pucked disc due to the fact they are race oriented units.
Old Jun 28, 2002 | 07:19 PM
ragejed's Avatar
Default Re: clutch chatter? (mike@coximport.com)
No way. then everyone on this board must have defective ACT units. I got one, and alot of people here do. if you give it more gas, it doesnt chatter. and the motor mount inserts got rid of like most of my chatter
Old Jun 29, 2002 | 01:47 AM
SIK IN DA HED's Avatar
New User
Default Re: clutch chatter? (ragejed)
clutch chatter when u shift is normal. i got an ACT HD 6puck.
anyone of you guys with the same clutch experience metal rubbin squeekin during idle?
Old Jun 29, 2002 | 06:14 AM
Default Re: clutch chatter? (dlplayboy)
Ask any of the guys here with an EXEDY organic unit if they have clutch chatter. I have driven a Civic, Integra, and a Prelude with the EXEDY organic. NO CHATTER!
As for the motor mounts having something to do with clutch chatter, that makes no sense what so ever.
Old Jun 29, 2002 | 08:24 PM
ragejed's Avatar
Well. I installed 2 inserts for the front torque bearing mounts. I guess the chatter made the motor vibrate too or wahtever. Either way, since I installed the 2 front mounts, most of the chatter went away. Go figure.
Old Sep 24, 2002 | 08:06 AM
SuperCivic's Avatar
umm..i bought my exedy organic clutch from *** imports. drove for about 5K miles w/ no chatter. it started chattering a few weeks ago. i also have a friend w/ an integra type r. his exedy organic clutch also did the same thing. i don't think i'll buy another exedy clutch .
Old Sep 24, 2002 | 08:50 AM
ragejed's Avatar
Default Re: clutch chatter? (SuperCivic)
my act chatters too tho...
an2ny888
Aug 25, 2007 03:11 PM
Nextelbuddy
Mar 5, 2004 06:06 PM
Beave0101
Mar 23, 2003 08:36 AM
ragejed
May 14, 2002 02:41 AM
hooptie157
Apr 16, 2002 06:42 PM
