b16 head with gsr cams and gsr block with type r pistons.
damn, can we please act a little bit more like a dick!!
Your results are going to depend on a your tune and other parts. The setup you have is a little on the mild side, but is a good starting point. Depending on what crank/rod combo you are running your compression will be around 11.0. With a decent intake manifold, header and cams you could easily see 180-190 at the wheels. A decent tune with a combo of the right parts can take you a long way.
eg4life1202
Nov 11, 2006 11:00 PM
EGinNY
Mar 7, 2005 07:45 AM
