JE pistons H22???
Old Dec 22, 2007 | 12:12 PM
H-EK22's Avatar
Default JE pistons H22???
Hey guys I just purchased a set of JE Pistons there 11.5:1 compression standard bore..... but i think i read in a past forum you have to sleeve a h22 When adding JE pistons... also do they fit the stock jdm h22 Rods???? sorry guys noob!
Old Dec 22, 2007 | 05:29 PM
kpowerdhatch's Avatar
Default Re: JE pistons H22??? (H-EK22)
Yes the H22's sleeves are made of a different material then other honda blocks. They can not be bored. You have to resleeve the block. The F20C of the S200 has the same sleeves.
Old Dec 22, 2007 | 05:34 PM
H-EK22's Avatar
Default Re: JE pistons H22??? (kpowerdhatch)
but the pistons are standard pistons 87mm.........does the block still require a bore???
Old Dec 23, 2007 | 09:09 AM
UK_Luder's Avatar
If you use those pistons in the standard block, both the pistons and the cylinder walls will be damaged in a very short space of time. This is due to the FRM (Fibre Re-enforced Matrix) material that Honda use in the H-Series blocks.
The only way around this, is to use a piston that has been specially designed to work with FRM, like the Jun or Mahle Gold Series pistons.
JE Pistons are NOT designed to be used with FRM, so your only choice if you want to use them, is to get the block bored out bigger, then have some iron liners pressed in. This will still give you a 87mm bore, but it will be iron, instead of FRM
Old Dec 23, 2007 | 09:11 AM
H-EK22's Avatar
Default Re: JE pistons H22??? (UK_Luder)
Where can i find these sleeves???
Old Dec 23, 2007 | 09:18 AM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H-EK22 &raquo;</TD></TR><TR><TD CLASS="quote">Where can i find these sleeves???</TD></TR></TABLE>
Iron sleeves? Talk to your engine builder
Old Dec 23, 2007 | 10:55 AM
hybrid2007's Avatar
Default Re: JE pistons H22??? (gibsanez)
I went for Darton Flanged liners. I think they were $160 for the set from race-eng.com.
Snce your going to the trouble of sleeving and buying new pistons you may aswell go to 88mm/88.5mm bore.
You could go to 90mm but then that leaves no room for a re-bore if things go **** up
Edit: Just realised you've already got your pistons so ignore most of my original post.
Old Dec 23, 2007 | 11:05 AM
H-EK22's Avatar
Default Re: JE pistons H22??? (hybrid2007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid2007 &raquo;</TD></TR><TR><TD CLASS="quote">I went for Darton Flanged liners. I think they were $160 for the set from race-eng.com.
Edit: Just realised you've already got your pistons so ignore most of my original post.</TD></TR></TABLE>
The JE pistons i bought are 87mm standard.......in another forum "98VTEC" told me those wouldnt work with darton iron Liners, he said i needed 87mm oversized(87.25) pistons, can someone clear this up please
Old Dec 23, 2007 | 12:05 PM
hybrid2007's Avatar
All depends on the internal diameter if the liners. I cant see why Darton wouldnt make the liners compatable with stock bore size but i may be wrong.
Are you sure he wasnt talking about using Mahle gold series pistons without re-sleeving?
Old Dec 23, 2007 | 12:23 PM
H-EK22's Avatar
No we were talking about My Je pistons on the Mahle gold serires pistons forum thow
Old Dec 23, 2007 | 12:53 PM
98vtec's Avatar
moderator emeritus
i was referring to using the JE's with darton liners. He needs to talk to darton to see if they make a 87mm standard bore liner. I have 89mm liners in my h23vtec so i dont know about stock bores.
Old Dec 23, 2007 | 01:05 PM
hybrid2007's Avatar
Default Re: JE pistons H22??? (98vtec)
I've just had the same liners installed and bored to 88mm.
I would be shocked if you cant run standard bore although its deffinately worth giving Darton a call
Old Dec 23, 2007 | 07:33 PM
H-EK22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid2007 &raquo;</TD></TR><TR><TD CLASS="quote">I've just had the same liners installed and bored to 88mm.
I would be shocked if you cant run standard bore although its deffinately worth giving Darton a call</TD></TR></TABLE>
Yeah guess ill just give darton a call and get this thing straightend out... hopefully i can use this pistons though
Old Dec 25, 2007 | 06:09 AM
hybrid2007's Avatar
Let us know what they say for future referance
Old Jan 26, 2008 | 03:36 PM
H-EK22's Avatar
http://www.raceeng.com/p-6000-....aspx
will this work???
Old Jan 26, 2008 | 07:56 PM
H-EK22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H-EK22 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.raceeng.com/p-6000-....aspx
will this work???</TD></TR></TABLE>
ANYBODY OUR THERE
Old Jan 27, 2008 | 05:49 AM
bluedlude's Avatar
at this point i would say go talk to your machinist. if they cant tell you what you should be doing, find a different machinist.
it says right on that sight 87mm. there is a chance that they could be undersized and you are supposed to have them bored to size but they are likely 87mm and will need to be rebored after they are installed to fix any misalignment from the install process.
Old Feb 1, 2008 | 08:52 PM
H-EK22's Avatar
Default Re: JE pistons H22??? (bluedlude)
Old Feb 2, 2008 | 07:51 AM
hybrid2007's Avatar
I would go with the flanged liners. Its only an extra $80 for the set.
Have you spoken to Darton yet?
Old Feb 2, 2008 | 10:09 AM
nitrousballa's Avatar
i am confused the whole way.you have je pistons correct not
mahle piston's as was mentioned earlier in the thread.
1-YOU will NOT be able to run those je pistons on a stock h22/23 sleeve
PERIOD.
2-you could have the block sleeved for your 87mm je pistons and call it the day.this is gonna range anywhere fron 700-1400 bucks.
3-you could get an F SERIES block and bore it like i did "problem solved"just have to do the modifications needed to make the h22 head work on an F SERIES block.
you just don't bore or hone a block and stick the pistons in.you bore or hone "EACH CYLINDER" to the piston and mark them for that cylinder.
as far as the min. you can bore a darton sleeve i am going to 86mm as in
the F series blocks are 86mm.this is if your going to sleeve
if i'm not right on any of this slap the hell out of me"and i won't hit you back"
Old Feb 2, 2008 | 05:22 PM
H-EK22's Avatar
Default Re: JE pistons H22??? (nitrousballa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitrousballa &raquo;</TD></TR><TR><TD CLASS="quote">i am confused the whole way.you have je pistons correct not
PERIOD.
if i'm not right on any of this slap the hell out of me"and i won't hit you back"</TD></TR></TABLE>
OK here, for you answers
1. It was clearly stated that you cannot run forged aluminum pistons on the FRM sleeves that come on the stock H22a block, but thanks for adding it again
2. I know i could sleeve the block precisely for the 87mm pistons with darton or benson but i kinda wanted to save money and not spend $1200 bucks if i didnt have to and there was different alternatives i could use...
3. I didnt know you could do Fseries block with the h22 head, never read bout it, interesting, i like i like
Old Feb 2, 2008 | 05:41 PM
let me see if i can fined that thread for you.
Old Feb 2, 2008 | 05:42 PM
https://honda-tech.com/zerothread?id=1046336
Old Feb 2, 2008 | 06:51 PM
H-EK22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitrousballa &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1046336 </TD></TR></TABLE>
****, that was a nice thread, very interesting!!
Old Feb 2, 2008 | 06:52 PM
FookMeHOndA's Avatar
hell yeah
JDMnegroCD5
Nov 24, 2008 09:05 PM
EM2Civic
Feb 27, 2005 05:01 PM
christoble
Jan 2, 2005 08:02 PM
solowerks
Dec 16, 2003 06:56 PM
