Need answers about Spoon Flywheel ASAP
Well does it grind on the USDM Starter? I have heard both and dont know the true answer
<-------------------- who is crossing finger's that is does not as it is the mail
Yes it grinded for me....
YES it didn't grind for some others..
either way I wouldn't worry if it is going into your SiR/Si....since the Mitsuba starter will work just fine with it....
It's the Integras with the Denso starter which experienced the grinding problems.
Mitsuba starter...No grind..
Denso starter...maybe grind....
Mitsuba starter = SiR
Denso = ITR
it bears no relation to what tranny it will go into. I use Mitsuba starter.
Denso = ITR
Try sending Ben@AJR (AJPwR) an IM; he should be able to give you a straight answer.
Damn I posted this like 2 min ago and already 1000+ views guess spoon get teh mouse clicking huh
He will tell you the exact same thing...
mine grinds half the time i try and start my car
then i get all these looks from everyone around the car thinking it's busted or something
better swap it out before the teeth off your flywheel gets all chewed off....
believe it or not, chromo doesn't stand a chance against the adamantium or whatever the hell the starter teeth are made outta!
Listen to RagingAngel - he's right.
I had the Spoon flywheel with the Denso starter and it grinded. Now I have the Mitshebishi (sp?) one and it starts everytime.
Just modify the flywheel.
cheaper than buying a starter.
I did this with a few of the JUN/other steel flywheels and voila! no grind
I'd imagine you'd have to remove the flywheel to do that IF it was already installed....Just trade up with an SiR/Si owner... and voila....his car now has a stronger starter.
To note, the Mitsuba is weaker when cranking and this was very evident when doing a compression test. Sounded like the car was lazy to turn over.
update: it is already here. all your spoon goodies are waiting at my place.
SPOONAGE
