setting timing odb0?
Old Dec 22, 2007 | 06:39 AM
jchrm80's Avatar
Default setting timing odb0?
I was reading an online manual I have for a jdm crxSir w/ first generation b16a1 in it, which is the same motor I have in my usdm crx. I found a page on ignition timing and saw the picture I circled on it. I have never seen this blue plug that it supposed to be jumped. So I go out and looked for about an hour and found no such plug near my blower motor. When I adjust the timing I use a timing light and do not jump any wires. Am I doing something wrong?
Old Dec 22, 2007 | 08:07 AM
4g hatch's Avatar
Default Re: setting timing odb0? (jchrm80)
on obd-o you gotta jump the connector. if im not mistaken i think on u.s motors its on the driverside[remember there driverside is on our passanger]
Old Dec 22, 2007 | 09:31 AM
zccr-xsi's Avatar
jump the little connecotr on the pssaenger side foot well,then let it warm up and losen the dizzy.shoot it with a tining light till u got the marks lined up and timing is set to 18 degrees topdead center.tighten the dizzy reshoot the crank pully to make sure it stayed in timie and then go ahead and remove the jumper in the passenger side foot well.
Old Dec 22, 2007 | 09:46 AM
jchrm80's Avatar
I realize it says the connector is in the passenger side footwell but for the life of me I cannot find it. I have looked numerous times to no avail. I understand fully how to set ingition timing if only i had that damn connector. What happeneds if you set it without jumping the connector? BTW thanks for the responses.
Old Dec 22, 2007 | 01:51 PM
97grnrs's Avatar
Default Re: (jchrm80)
every time i jump that connector it makes no diff so i dont even jump it now.. some are under the hood some are next to the blower box tucked up with other wires.
Old Dec 22, 2007 | 02:58 PM
jchrm80's Avatar
lol well that makes me feel a little better knowing it prolly doesnt do a lot. thanks.
Old Dec 22, 2007 | 05:09 PM
db1_jdm's Avatar
when I adjust ignition timing on my obd0 db1 it makes no diffrence if I jump the connector or not. Car runs fine
Old Dec 22, 2007 | 05:14 PM
zccr-xsi's Avatar
i dont think it matter ehtier cause ive never jumped it with obd0 only time i use the jumpers would be checking obd1 codes.but if u have to know its right by the pa sensor.its the 2 wire clip cant miss it! one wire will be soild brown
fenix4o9
Jan 23, 2010 07:40 PM
Jmumblez2001
Nov 3, 2006 01:36 AM
SNsLude
Jun 1, 2005 11:27 PM
DieMaster
Jul 2, 2004 09:09 AM
type Gendy
May 18, 2003 02:53 PM
