would this cut though the floor?
Old Dec 21, 2007 | 11:41 PM
JDM_CRX_PLEASE's Avatar
Default would this cut though the floor?
4 SPEED ROTARY TOOL KIT
Versatile tool is ideal for shaping, sanding, deburring, grinding and polishing. Effortlessly removes rust on metals, plastic and wood. Thirty piece kit includes the most popular accessories packed neatly in a blow mold case. Double insulated.
Motor: 120V, 60 Hz
Direct drive
4 step speeds: 6500, 10700, 14000 and 22000 RPM
Collet sizes: 1/8'' and 3/32'' diameter
Old Dec 21, 2007 | 11:49 PM
Doostur's Avatar
Looks like a drummel I baught. The only thing i see cutting through the floor are those mini circle sander things which break off very easily.
Old Dec 22, 2007 | 12:08 AM
3lo's Avatar
3lo
no, there is no way you can get through the floor with that dremel, its made for soft materials, read the manual that came with it.
get something like this. its called disk grinder and you can find a cheap one for about 60 bucks. and the blade will go from $5-$10
Old Dec 22, 2007 | 05:03 AM
burgandybeast's Avatar
Default Re: (3lo)
Just curious...Why cuttin the floor?
Old Dec 22, 2007 | 05:05 AM
Doostur's Avatar
Default Re: (burgandybeast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burgandybeast &raquo;</TD></TR><TR><TD CLASS="quote">Just curious...Why cuttin the floor?</TD></TR></TABLE>
Weight reduction. He is removing the useless areas
Old Dec 22, 2007 | 05:15 AM
Default Re: (Doostur)
Uhhhh...A honda is a unibody car. You cut out the floor your cutting the frame.
Not a smart idea...Especially if its a DD. Just my 2¢ o and btw.
If you let anyone ride with you in a hackjobbed car..
And you hurt/kill them..Your gonna be spending some cheese or doing some jail time.
Old Dec 22, 2007 | 11:26 AM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burgandybeast &raquo;</TD></TR><TR><TD CLASS="quote">Uhhhh...A honda is a unibody car. You cut out the floor your cutting the frame.
And you hurt/kill them..Your gonna be spending some cheese or doing some jail time. </TD></TR></TABLE>
He's not cutting out all the useless floor... That was a joke.
Old Dec 22, 2007 | 11:31 AM
z6hatchboy's Avatar
die grinder, recipricating saw, or a grinder like "3lo" mentioned, die grinder would be more versatile though, build your forearm for the recipricating saw though .
Old Dec 22, 2007 | 01:04 PM
h-duced's Avatar
Default Re: would this cut though the floor? (JDM_CRX_PLEASE)
I think he could use that thing but he better buy like a 1000 cuting wheels with it
Old Dec 22, 2007 | 07:23 PM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
A grinder will be great, if you like fireworks.
I rather use a saw zaw instead. Is it spelled "saw zaw"?
Old Dec 22, 2007 | 07:26 PM
Default Re: (phyzJunkieCivic)
What are you going to cut out then?
Cutting into floor puts major weak spot in the middle of car.
Old Dec 22, 2007 | 07:31 PM
94excivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phyzJunkieCivic &raquo;</TD></TR><TR><TD CLASS="quote">A grinder will be great, if you like fireworks.
I rather use a saw zaw instead. Is it spelled "saw zaw"?</TD></TR></TABLE>
i thought it was called a sawz-all, which is what i would use if i were to cut a floor
Old Dec 22, 2007 | 07:45 PM
Default Re: (94excivic)
someone please explain to me why frame weakness for weight reduction is cool..
&gt;.&lt; this thread is making my nuts hurt.
Old Dec 22, 2007 | 07:46 PM
Libertariat's Avatar
Ek Forever y0!
Not a smart idea...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burgandybeast &raquo;</TD></TR><TR><TD CLASS="quote">someone please explain to me why frame weakness for weight reduction is cool..
&gt;.&lt; this thread is making my nuts hurt. </TD></TR></TABLE>
Someone please explain to me why you two can't expletiveing read.
Old Dec 22, 2007 | 07:53 PM
Default Re: (ek forever guy)
he said he wasnt cutting out "ALL" the useless floor..
He never said it was a joke.
Old Dec 22, 2007 | 07:55 PM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burgandybeast &raquo;</TD></TR><TR><TD CLASS="quote">he said he wasnt cutting out "ALL" the useless floor..
He never said it was a joke.</TD></TR></TABLE>
Old Dec 22, 2007 | 07:56 PM
I'm just saying a few extra lbs isnt worth risking your life.
After being pretty much t-boned from the passenger side
you kind of worry about stuff like that especially at high speeds.
Old Dec 22, 2007 | 08:01 PM
Sundown's Avatar
a dremel will not cut through the floor. I tried using it during my auto-manual swap and I nearly messed it up..
Old Dec 22, 2007 | 08:35 PM
NOFX's Avatar
H-T White Ops
Maybe, just maybe, he's not meaning to cut out the entire floor. Maybe he's doing an auto to manual swap. Maybe he just means to put a hole in the floor for drainage.
Why in hell do you jump to the conclusion that he's going to start cutting out massive chunks of his floor?
Old Dec 23, 2007 | 02:56 AM
Default Re: (NOFX)
im doing auto to manual conversion
Old Dec 23, 2007 | 03:06 AM
Doostur's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CRX_PLEASE &raquo;</TD></TR><TR><TD CLASS="quote">im doing auto to manual conversion</TD></TR></TABLE>
dropcivic
Jul 26, 2007 03:16 PM
Dropped90Integra
Feb 13, 2005 06:27 PM
