Transmission Removal
Old Dec 21, 2007 | 08:27 PM
d'sb16a2's Avatar
Default Transmission Removal
I'm a newbie on removing a manual transmission to replace a blown throwout bearing and the clutch, pressure plate, and flywheel while I'm in there, i followed the service manual and followed a topic: DIY/How to: Tranny Removal by Ricey McRicerton which i found in NEW FAQ'S INDEX - '92-'00 Civic / Del Sol, what i don't understand is why do i have to remove the left driveshaft and intermediate shaft when everything is on the right side of the vehicle, if there is an easier way to remove this could some one suggest a way or possible detailed pics better than the Tranny removal Topic? Thanks its greatly appreciated!
Old Dec 21, 2007 | 08:30 PM
z6hatchboy's Avatar
Because the shafts go inside the tranny, its what put the power from the tranny to the wheels. Justs undo the tie-rod and upper control arm, let that assmebly lean over and pop em out.
Old Dec 21, 2007 | 08:38 PM
Bense's Avatar
Default Re: (z6hatchboy)
it's easier to remove the lower ball joint.
I assembled a transmission, removed my transmission, installed newly assembled transmission in 6 hours today
Old Dec 21, 2007 | 08:42 PM
z6hatchboy's Avatar
Default Re: (Bense)
Thanks
EkEire
Nov 10, 2006 06:21 AM
4thgenlude
Sep 12, 2004 10:10 AM
afxtwin
Sep 24, 2003 12:32 PM
dwtyper
Dec 30, 2002 07:24 PM
JPP
Sep 3, 2002 07:37 AM
