Compustar 2WFMR install // prewired relay question
Old Jun 27, 2002 | 11:12 PM
funkylemons's Avatar
Default Compustar 2WFMR install // prewired relay question
compustar doesnt really include directions.. or detailed ones at that... there are two prewired relays on this thing, a relay for a 2nd starter and a relay for starter kill... i know how starter kill works but how do you wire the 2nd starter in? there are two wires coming off the relay, do you split the 2nd starter?, but if you do that why are the two wires different colors and guages?!.. anyone please!?
Old Jun 28, 2002 | 06:13 AM
Default Re: Compustar 2WFMR install // prewired relay question (funkylemons)
anyone?
Old Jul 25, 2005 | 10:40 PM
Built_For_Boost's Avatar
The blue thicker wire goes to any car accessories you want to power up. The purple or violet smaller wire is hooked up to an aux output or channel. For Example: I want to start my car. The air condition does Not turn on until I press a channel on my remote to turn on the A/C.
If you don't want to waste a channel, you can tap into the Violet wire of the starter kill.
So when you Remote start the car, the car and the accessories are on at the same time.
I hope that helps.
Old Jul 26, 2005 | 09:15 AM
fcm's Avatar
fcm
Old Fart
The extra relay is for a 2nd ign., acc., or starter if you need one, what you use it for will depend on how/what you trigger the relay with, and that depends on what compustar you have, here is help if you need it. http://www.staub.ca/tech/manuals.html 94
Old Jul 28, 2005 | 05:52 PM
Default Re: Compustar 2WFMR install // prewired relay question (fcm)
Awesome info!
Schultzie
Jan 23, 2013 09:46 PM
Canadian_EF
Audio / Security / Video
Jul 23, 2012 09:04 AM
delsolo95
23
Nov 8, 2010 08:13 PM
Hanmin
12
Aug 8, 2010 04:18 PM
3 G's
Oct 25, 2003 04:54 PM
