Losing clutch fluid and clutch is slipping - ideas?
Old Dec 21, 2007 | 01:12 PM
hondapwr's Avatar
Default Losing clutch fluid and clutch is slipping - ideas?
My clutch started to slip more and more this week, and I noticed that my clutch fluid was low. It never went dry, but it was low. I also noticed blackish grey stuff floating in the fluid. Any idea what this is? Is the slipping clutch and fluid problem related?
Old Dec 21, 2007 | 01:13 PM
93egSLEEPER's Avatar
Default Re: Losing clutch fluid and clutch is slipping - ideas? (hondapwr)
your tranny is running out of fluid?? i wanna make sure im reading all this correctly.
Old Dec 21, 2007 | 01:16 PM
speedooo's Avatar
Default Re: Losing clutch fluid and clutch is slipping - ideas? (93egSLEEPER)
you need to be more specific. are you checking the reservoir or the actual trans? loss of trans fluid and a slipping clutch means that fluid is getting into the clutch housing and your clutch is being killed prematurely. the reservoir being low means that theres a leak somewhere.
hondapwr's Avatar
My clutch master cylinder is running out of fluid. I have a hydraulic clutch.
Old Dec 21, 2007 | 01:53 PM
black0hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedooo &raquo;</TD></TR><TR><TD CLASS="quote">you need to be more specific. are you checking the reservoir or the actual trans? .</TD></TR></TABLE>
how could you look into the trans to see blackish gray stuff floating in the fluid? check you clutch master cylinder under the dash they usually go out there first if its dry look for leaks by the slave cylinder. fix that first. flush out the fluid since theres crap in it. then if the clutch is still slipping you probably need a new one.
Old Dec 21, 2007 | 03:34 PM
924doorEG's Avatar
same thing happend to me on the freeway all my fluid was lost and it wouldnt shift into any gears, your master cylinder is bad and needs a new one and as far as the stuff floating around its dirt from your bad clutch/master cylinder.
Old Dec 21, 2007 | 05:25 PM
hondapwr's Avatar
Default Re: (924doorEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 924doorEG &raquo;</TD></TR><TR><TD CLASS="quote">same thing happend to me on the freeway all my fluid was lost and it wouldnt shift into any gears, your master cylinder is bad and needs a new one and as far as the stuff floating around its dirt from your bad clutch/master cylinder.</TD></TR></TABLE>
Ahh thanks! How hard was it to replace?
Old Dec 21, 2007 | 05:27 PM
924doorEG's Avatar
not too hard, if you havent done it i'd take it to a shop, it wasent expensive to fix eaither the MS itself was 40 bucks and the labor to put in, until you fix it though KEEP FLUUID IIN IT or your clutch will go byebye
Old Dec 21, 2007 | 05:31 PM
hondapwr's Avatar
The clutch already slips a good bit with the clutch master cylinder full of fluid. I think it's already shot from having a malfunctioning master cylinder for so long. :-(
Did you replace the master (on firewall) and slave (on tranny) or just the master?
Old Dec 21, 2007 | 05:34 PM
924doorEG's Avatar
i replaced it ALL slave cylinder,master cylinder, and the clutch. but your slave might be okay. but deffinately replaces slave, and master before clutch or at the same time
Old Dec 21, 2007 | 05:40 PM
hondapwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 924doorEG &raquo;</TD></TR><TR><TD CLASS="quote">i replaced it ALL slave cylinder,master cylinder, and the clutch. but your slave might be okay. but deffinately replaces slave, and master before clutch or at the same time</TD></TR></TABLE>
I just checked online. I can get the master and slave for less than $20 so i might as well do both.
The clutch is probably shot, so I'll replace that too along with the axle seals, rear main seal, and any other seals that are in the area when I take the tranny off the block.
Anything else you can think of that I might as well replace while I've got it all apart?
Old Dec 21, 2007 | 05:42 PM
924doorEG's Avatar
resurface your flywheel! lol or get a new one man. did you look at the set online at ebay?
Old Dec 21, 2007 | 05:46 PM
hondapwr's Avatar
I have a few sites I like to shop at. I'm trying to get most of the parts for this repair at
http://www.coximport.com/
I'm looking at the Exedy clutch master/slave cylinders with an ACT organic clutch kit. I might get a new flywheel if resurfacing is going to cost anywhere near $200.
Old Dec 21, 2007 | 05:48 PM
924doorEG's Avatar
best setup around exedy oem or stage one with findoza flywheel!
Old Dec 21, 2007 | 06:05 PM
hondapwr's Avatar
I have a Clutchmasters clutch and ACT flywheel on my B16A powered Civic and I love it. The ACT clutch seems reputable and costs a little less than the other brands. I always wanted to give ACT a try since I liked their flywheel.
One thing's for sure, I'm going to make sure my clutch cylinders are working correctly before using the new clutch! How can you even tell that the cylinders are starting to fail?
Old Dec 21, 2007 | 06:09 PM
924doorEG's Avatar
If a slave cylinder is bad, there will be an external leak that you should be able to see. Plus, the fluid level would go down.
A master cylinder can fail two ways.
It can leak fluid out and you would see the fluid. In this case, the fluid level would go down.
A master cylinder can also "back bleed" and you will not see any fluid leaking. The level will never go low due to the fact that it's never leaving the system.
Old Dec 21, 2007 | 06:11 PM
hondapwr's Avatar
I meant can you figure it out while driving? Like, will you have to push the pedal down almost to the floor to get the clutch to disengage from the flywheel?
Old Dec 21, 2007 | 06:12 PM
924doorEG's Avatar
yes
Old Dec 21, 2007 | 06:14 PM
924doorEG's Avatar
trust me though, you know you master cylinder is going out, if one goes out and you replace it the other dose really soon. i replaced my master cylinder and then one week later my slave cylinder went out so even if it shows its good and its just a master clyinder, your gonna want to replace both.
Old Dec 21, 2007 | 06:16 PM
hondapwr's Avatar
I was just thinking of my other Honda. Maybe I'll just pay $40 and replace the master and slave on both to be safe. It sux your clutch gets eaten up as the cylinders die.
Flux
Jan 17, 2012 03:32 PM
eL
23
Sep 21, 2004 03:40 PM
phantom_sol
13
Sep 9, 2003 03:22 PM
Qwikrex
Apr 20, 2003 03:27 PM
