Suspension & Brakes Theory, alignment, spring rates....
Was my alignment done right? (nooB)
Old Dec 21, 2007 | 12:10 PM
DJLikwid's Avatar
Default Was my alignment done right? (nooB)
http://s271.photobucket.com/al...t.jpg
Hopefully this works. Any input is appreciated.
Old Dec 21, 2007 | 12:11 PM
DJLikwid's Avatar
Default Re: Was my alignment done right? (DJLikwid)
Old Dec 21, 2007 | 01:51 PM
non-VTEC's Avatar
looks like they adjusted toe in the front......your steering was off center to the right and it should be pretty straight now.
everything else is fine since camber is not adjustible.
Old Dec 21, 2007 | 06:25 PM
mormonboy's Avatar
Default Re: Was my alignment done right? (non-VTEC)
your Toe in front and Toe in rear are within spec.
good job. have a cookie.
Old Dec 21, 2007 | 07:36 PM
EK_B's Avatar
Yay for your tires!
Old Dec 22, 2007 | 09:33 AM
hatchling37's Avatar
You'll be just fine. Your toe isn't matched in the front, but as long as your steering wheel is straight, I'd be satisfied. And I'm a front end/ alignment tech.
Old Dec 24, 2007 | 06:22 AM
DJLikwid's Avatar
thanks guys
Old Dec 24, 2007 | 09:19 AM
Targa250R's Avatar
be professional
Everything looks good, but I'd be surprised if it doesn't pull to the left a bit with the wheel held straight.
As long as the car tracks straight for you, it'll be fine. Tire wear should be good.
raidacaipo
20
Feb 27, 2010 03:05 PM
dafuzzbudd
22
Feb 20, 2007 11:17 AM
Nothing.Special
Suspension & Brakes
May 23, 2005 08:08 AM
BigBadBuford
Aug 21, 2003 12:21 PM
ultimatehonda
Jul 8, 2003 03:28 AM
