1990 Accord - wiper fluid motor not working
Old Dec 21, 2007 | 11:37 AM
voodooutt's Avatar
Default 1990 Accord - wiper fluid motor not working
hello, did a search on wiper fluid motor not working, could not find anything. soooooooo...... I checked the fuse first thing, and its not blown. I am not sure if theres a relay in the circuit either.... if there is, which one is it? And if the relay is not bad, i'd probably assume the motor went bad.
If the motor is bad, would is be easier to just replace the whole bottle or just the motor itself? I haven't dug too much underneath the car to see what kind of a job it would be
-Thanks
Andrew
Old Dec 21, 2007 | 01:46 PM
GrantD's Avatar
Default Re: 1990 Accord - wiper fluid motor not working (voodooutt)
well whenever there is a switch or relay in question the first thing I always do is grab a multimeter and check if there is voltage past the switch or relay. That will isolate a problem pretty quick. If you have voltage past the switch before the motor you can bet that your motor is bad and that it needs to be replaced. This of course has to be checked when the switch is engaged so you'll need a buddy.
If you don't have a multimeter as most people don't tend to you can buy a cheapy one for less than 10 bucks that will tell you what you need to know. It's definitely a good tool to have around.
this is 10 bucks
http://www.sears.com/shc/s/p_1...meter
thats way nicer than the one I have.
Before you replace the motor make sure that the tube isn't clogged by trying to blow air through it with either a compressor or your mouth if you're poor.
Old Dec 21, 2007 | 09:43 PM
srlance24's Avatar
to see if motor is bad u can also just take the short rubber hosing off that connects the line from the hood to the rest of the system, then hit the squirts and if fluid is coming out at a good rate, then whats happening is that when u close your hood the short rubbing hose is ceasing, stopping the flow of wiper fluid.
That's what was wrong with mine, and its pretty typical with 90-93 accords. 2 second fix, cost nothing
Old Dec 22, 2007 | 09:28 AM
voodooutt's Avatar
Default Re: 1990 Accord - wiper fluid motor not working (srlance24)
the motor does not run when i pull the lever back on the steering column. so, I did use a multimeter and started nosing around and finally traced a corroded wire near the motor. spliced it out, and done.
Old Dec 24, 2007 | 09:08 PM
starchland's Avatar
nice to find out the problem. ive seen other times when the line is either broke or its being squished when the hood closes.
94 IntegraLS
Feb 11, 2013 07:56 AM
Juan_Mitosis
Mar 10, 2009 09:49 AM
yh8me901
Dec 13, 2008 06:56 PM
Olias
Nov 22, 2008 02:36 PM
