d16y7 turbo
https://honda-tech.com/zerothread?id=635014
this will get you close. it isnt a y7, but the only real differences will be throttlebody plumbing. g/l have at it.
The Y7 install is the same as the other SOHCs with the acception of the vertical throttle body. If you are using a kit made for the EX you will need to add a 90 degree piece to connect the TB to the upper charge pipe.
Also, if you are using a 92-00 Civic "colt on" kit then the DP will fall short of connecting to the stock exhaust of a 96-00 DX w/ a D16Y7.
You can probably find more detailed install pics at http://www.d-series.org or http://www.turbod16.com
Teluan
Sep 1, 2001 08:18 PM
